  New Posts New Posts RSS Feed - 1:1 transmisson  fluid milky
Jtandy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtandy Quote  Post ReplyReply Direct Link To This Post Topic: 1:1 transmisson fluid milky
    Posted: June-06-2010 at 2:20pm
Gang need advice   my tranny fluid is a milky, I put in a plastic bottle and have been watching since sat morning. Appears to have a little watter on top. about 1/4 inch and the rest is still a milky color. I think I need to replace the tranny cooler. But is there any other problems that you guys have seen with this. Thanks in advance Jon
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2010 at 2:24pm
Jon,
Chances are at 99% that it's your cooler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtandy Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2010 at 2:26pm
Thats kinda what I thought. but better to research than just replace parts. Thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2010 at 3:46pm
You can pull your cooler off and fill it with water to check it.
Tim
Mal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mal Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2010 at 4:49pm
My 99 SN was doing exactly the same, at first i thought it was condensation as although the fluid was milky there never seemed to be an excess amount of fluid on the dipstick, I replaced the fluid 4 times, always the same after use, eventually replaced the cooler and the problem has gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2010 at 5:14pm
Malcolm,
Trans fluid gets out via the cooler just like water gets in via the cooler!
Mal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mal Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2010 at 6:14pm
Malcolm,
Does the pump in the tranny pump through the cooler or suck through? just thinking that if it pumps then you would loose oil but not gain any water due to the pump pressure being greater, but if it sucks through the cooler then it would pull water in through any small holes but not neccersarily loose oil.
As i said i replaced mine and all is now sweet
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2010 at 7:26pm
Malcolm,
Pumping or sucking really doesn't matter. Keep in mind there's no suction or pressure when the engines not running. Running to sitting does produce heat/cool - expansion/contraction cycles.
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2010 at 1:12am
Are you kidding?
john
"Loud pipes save lives"
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2010 at 1:50am
Are you kidding?
john
I hope Quinner don't see that comment'''''''''''''
I get milk either way.............
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2010 at 2:07am
yikes..
john
