Couple issues |
TRIP
Gold Member Joined: December-08-2007 Location: Costa Rica Status: Offline Points: 629 |
Posted: July-19-2010 at 3:08pm |
Hola, just had a not so good weekend. '85 with 351.
First: shot impeller. Overheated so one exhaust hose blew. Changed impeller and found a hose (used on trucks) that I hoped would last until I got 2 new ones from the US. Also opened up thermostat housing to see if I could find some pieces of impeller in there, but probably did it wrong (opened up from the top, probably should have opened from the front?). Anyway, put it back, went for a test run and ran fine. However, when idling temperature stayed just above minimum. More rev's/more speed temp went to 160 and stayed there. What might cause the temp to stay so low at idle? In the mean time, when working on the engine, I saw this ring (the one on the left) so I tightened it where it is in the pic. Long time ago I heard some weird noises, thinling it might have been the damper plate, but the sounds later disappeared. Might have been this. Doesn't seem like it could have done any harm. Then, 10 minutes after the successful test runs I went out; no throttle. Found this: Time for a new cable I guess? How do you change the cable? Thanks for your help! |
Your 160 temp sounds normal. It will go up under a engine load. Never run your engine without water. That will burn up the impeller. Your old impeller has been run dry.
The set collar on the shaft is there for safety. If you snap a shaft at the coupling (common from a major misalignment problem) then the collar will keep the shaft in the boat and not sliding aft. Yup, looks like it's new throttle cable time! Change out the shift cable at the same time. The new cables are pulled in when the old are pulled out by attaching them together. |
TRIP
Hi Pete, thanks very much.
I haven't and I would never let it run dry. Guess the water intake must have been clogged. Both speedos also acted up that day so must have been lots of dirt/plants/whatever in the water. However, before this incident the temp would also go up to 160 in a couple minutes at just idle. Now it only gets there under load. Do you have to take off the morse control to change the cables? |
Yes. it just drops down.
And buy fresh pivots, yours look already 1/2 gone. Just elect tape the new cable to the old one and pull through. |
TRIP
That's good, the control housing needs some new paint anyway.
I read in another thread that skidim's uflex cables are inferior to the red cables (that I have now as well). There was a link to go2marine.com that carries them, but they don't have stock 17ft, only custom made which takes 5 days. Any other online place to get them? |
I got a cable in 36 hours from lighthouse marine on long island, but i am much closer than you. Maybe they ship out of country.
The last set of cables I got (this spring) were from Jamestown). I went for the regular ones instead of the red jackets. I figured the originals lasted 33 years plus they were in stock. One was still good but the other was showing signs of getting stiff.
Keep the bends as gentile as possible. |
TRIP
Thank you very much gentlemen!
A few more questions, hope you don't mind; For where the wire is, should I get the control cable connector (like this ? And how do I get the morse control off? There's 3 screws, 2 behind the lever and 1 in front. I loosened the 2 bolts on the back of the 2 behind the lever and the screw in front of it but it doesn't move yet. Am I on the right track? I'd also like to trn the steering wheel 180 degrees as it's upside down now and therefore blocking a gauge. What's the way to go? Just loosen the allen screws or is there more to it? |
