  New Posts New Posts RSS Feed - Fuel Gauge Reads Backwards.
79Tique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Gauge Reads Backwards.
    Posted: August-11-2010 at 10:53pm
Anyone know what causes a fuel gauge to read full when empty and empty when full? I tried swaping the positive and neg wires on it but that was not the problem.
Work to live, not live to work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2010 at 11:03pm
Gabe???,
The only reason there's a negative wire on that thing is due to the lighting. The neg has absolutely nothing to do with the gauge!! Someones put in a mismatched sender/gauge!!! Tell me more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2010 at 5:57am
Pete,
Thanks for chiming in. The gauge is in my buddies Alpina boat. I'm installing a Perfect Pass for him and he asked if I knew what is up with the backwards reading fuel gauge. So I'm looking in to it for him.
The Alpina is a 1999 powered by a Mercruiser 5.7 MPI just like many Malibu boats of the same vintage. It's a pretty "plane Jane" boat with really basic equipment.
He told me the gauage reads empty when full and full when empty. He also said it moves steadily and consistantly as the tank empties like it's working properly but just backwards. I thought it seemed like something is connected backwards.
Of course he left me the boat with 1/2 a tank so it's hard to know if I have corrected the problem. The gauge at the dash has a pink wire on one side a blue wire on the other and black in the center. I tried swaping the wires around but the only way the gauge works at all is with the wires the way I found them.
I was suspecting the problem was at the tank from the start but thought I would start with the easiest part to get to first. I can't find much information about these boats but I thought some hear might have some ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2010 at 9:04am
Gabe,
See what you can find out from the manufacturer of the gauge regarding the Ohm range needed at the sender.
harddock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2010 at 9:56am
Try to maintain 1/2 tank at all times
Seriously, the problem is on the sender end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2010 at 1:54pm
Thanks guys. I see what I can find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2010 at 3:02am
This is what I found. I pulled the sender unit out of the tank and sure enough when the float arm was up it made the gauge read empty and full when down.
I decided to take the sender apart and reasemble it with the mechanism inverted. Put the sender back in the tank reconnected the wires and the gauge reads correctly now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2010 at 6:48am
Gabe,
It's always a great feeling when you are able to fix something! Yes, many of the "universal" senders can be reversed. I'm glad you were able to determine that.
65 'cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2010 at 12:23pm
Couldn't you have just run the boat upside down?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2010 at 3:40pm
Gabe,
Yeh sure does Pete. On that note I never followed up on a thread I started a while back about my 94 "burning" oil. At that time the boat had about 450 hours on it, ran great but used oil like crazy. Some folks told me I could try things but in the end the motor would need a rebuild.
An auto mechanic friend and I pulled the valve covers and a few other things and found no valve seals at all. My mechanic friend said he had never seen that. We used the cotton rope in the compustion chamber trick to put new valve seals on and now the boat burns little to no oil.
We're now at a little over 700 hours and running great and going through a lot less spark plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2010 at 3:52pm
I thought about it but I would have had to take the tower off to get the boat on the trailer then. Although that probably would have been easier than all the floor disasembly/reasembly I had to do to get to the gas tank.
On this brendella/Alpina the tank is in the floor right about where the dash is. To get at it you have to pull a floor panel, to pull the floor panel you have to remove the pylon, to pull the pylon you have to pull the side floor panels, to pull the side panels you have to take out all the seats. At least with all that out of the boat it was real easy to run the wires for the perfect pass. No wire snake needed.
