  New Posts New Posts RSS Feed - Stringer dimensions
Stringer dimensions
hotboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Topic: Stringer dimensions
    Posted: September-11-2010 at 12:35pm
Can anyone give me dimensions for stringers in a 2nd generation ski nautique? Uncle has a sawmill guy showing up and I can get some made if I have the numbers. Thanks Brian
Brian
harriss28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harriss28 Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 2:17pm
do you know of any properties for sale on Conneaut Lake? Im from Titusville?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 3:15pm
Everything is for sale around here lol. Take a drive up and look around. Do you boat here? Most everything for sale is online as well.
Brian
65 'cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 3:36pm
What dimensions are you looking for? I think you will need two 2 x 8 x 14's (mains)and two 1 x 8 x 14's (secondaries). The 7 1/4 will be very close, If you are having them cut, you may want them taller to give you more leeway to do final scribing, start with them tall, scribe them. in then rip them to height.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 3:42pm
That is what I was looking for thanks Gary. Summer seems to have ended so I guess its time to make a mess.
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 4:05pm
My stringers were 7-1/2 at the highest point but CC had a lot of build up on the top too get them to height.
I wanted to avoid the unnecessary build up so I went with 2x10s. If your cutting your own it wouldn't hurt to go a full 1" on the secondaries.
Remember to allow for shrinkage as they dry.
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 6:09pm
Nor would it hurt to go a full 2" on the primaries.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 6:53pm
Originally posted by hotboat hotboat wrote:
Uncle has a sawmill guy showing up Thanks Brian
The normal for kiln dried construction is around 13%. If this "sawmill guy" is any good he will have a moisture meter and will be able to check the % on the lumber he's suppling. I like to see it around 8% before you use it for stringers.
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 7:14pm
Scott (sbranum) used true 2x's and almost ran into a problem with the widths of the exhaust channels and main bilge area. Just make sure you take into account the extra width if you do that. There is more room on the SN so it wont be a problem just make sure you have the clearance you need for the exhaust and engine.
1973 Skier
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 8:18pm
I went with 2X10 as well. I think I got a much better fit than the factory. Also, didn't have to scab a piece on for the gas tank mount. Mines an 82, so I guess that's third generation SN. BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 11:23pm
Thanks guys for the input, still wiatin to hear from a 2nd gen guy like uk? Im not in a hurry on this project, its just a practice job b4 cuttin the bfoot up
Brian
srbranum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2010 at 11:48pm
Keegan,
I would like to blame the problem I encountered on my primaries being a full 2" but honestly it was more of me not taking my time to measure every dimension more carefully before removing the engine and the old primaries. In my next life when I do another stringer job, it will be like Keegan's or Okie boarders
I have to keep her running 'cause I can't afford a new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2010 at 1:09am
Keegan,
Your work is great Scott! You are too modest. You rebuilt that boat so fast I was starting to feel incompetent!
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote harriss28 Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2010 at 7:27pm
I havent been to Conneaut in a couple years. Its a little to busy for me. I boat mostly at Tionesta ince its only 15 miles away. Ill have to check out the real estate there. Thanks
