  New Posts New Posts RSS Feed - ZDDP....ZINC
ZDDP....ZINC
 Post Reply Post Reply Page   123>
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Topic: ZDDP....ZINC
    Posted: September-22-2010 at 3:45pm
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 4:10pm
Tim I cant open the link
1973 Skier
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 4:19pm
Nope, the link won't work.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 4:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 4:36pm
SO Camguard is a supplemental additive that you add to your existing oil? More interesting info. Thanks!
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 4:50pm
It's an add for "Camgard" Mostly factual, a little bias.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 4:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 5:28pm
Combustion gasses degrade engine oil more than just about anything. Total Acid Numbers (TAN) is a huge thing. Always change the oil often and before a long lay-up. Oil with a TAN over 2 or so will acid etch the metal it comes in contact with, soft metals more (bearings and the cam). High zinc oils are what we use in these boats to protect the soft case hardened cams from valve spring pressure.(high zinc being over 1000 parts per million) Most diesel oils are satisfactory and most racing oil.
If you'd like I can check your oil TANs and run a Spectro analysis of 20 constituants on your oil when you change it. I only need a small mid-stream sample. I do mine when I change the oil, I've offered to do it before for all CCF's but no one has taken me up on it. (I'm a certified joint forces oil anaylsis operator)
- waterdog -
78 Ski Tique
65 'cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 5:35pm
Andy,
I had a distributor failure, which lead to a blown head gasket, which led to a very large quantity of milkshake in the crankcase. It is all back together now, I would like to take you up on your offer. Would your tests let me know if I did much damage to the bearings, etc.? I'll send you an oil sample when I do winter layup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 6:06pm
Gary,
Sure, check my e mail address and shoot me a note. I'll send ya a couple of sample bottles.
I can check for tin,lead,copper and do a check for soluble water too.
With a base line and samples at oil change you can track engine wear.
- waterdog -
78 Ski Tique
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 6:18pm
Tim, we call it "snake oil" down here.Roller motors do not need the high levels that flat tappet motors need.
This topic has been " beat to death" lottsa time spent researching the role played by the ZDDP's and the easiest way to avoid lobe wipe out.Do a search but run in your motor what you like, just don't spread stupid to the newbies.
Oil is cheap Cams are not
Valvoline VR 1
Shell Rotella T 30 weight
Shell Rotella T 40 weight
These oils have the needed % of ZDDP to protect your cam and lifters....
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 6:22pm
The Lake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Lake Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 8:29pm
I've been usin' vr 1; hard to get the straight weight Rotella here, maybe I should try Tractor Supply.
Walk on Water
www.coldwater.me
69 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 8:39pm
behindpropeller,
I looked in your profile are you realy 99 ?
Your post IS worthy and good information. Just a grain of salt is needed. (flavor to taste)
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 8:48pm
Andy,
Tried to email through the site, got a syntax error, try me at
emmcol at ymail dot com
horkn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 11:07pm
Unfortunately this info appears to be old and outdated.
Rotella, and VR1 are not the same oils they used to be only a couple years ago.
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 11:21pm
my napa rep just went to a seminar last week they told him to use rotella or valvoline racing oil. if its dated info then the seminar was a waste of time and money. i wonder whos right..
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2010 at 11:37pm
Valvoline VR 1
Obviously you didn't read the link. It specifically talks about flat tappet motors.
Obviously you do not under stand the term "snake oil"! Words on a piece of paper don't make it so. Why not buy an oil that has all the additive already in the bottle.
Horkn, no mention of these oils being the SAME.
The order listed them the easiest to purchase. The VR1 can be bought in any Auto Zone, the Rotella T single grades a little harder.
Shell and Valvoline are two separate refineries, hence two different names with different oil products. The common being they have the highest levels of ZDDP.
davidg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 1:13am
Guys....I run Rotella T 15W40 (much easier to find). I read on the Shell Rotella formum a year or so back that the 15W40 is higher in ZDDP than the straight weights. Any truth to that?
If not higher in the ZDDP, could it be at least the same as the straight weights? Just wondering?? Is there a way to verify how much each grade has in it. I think the 15W40 is used mostly in diesels. So, if its got enough of the goodies in it for diesel use, shouldn't it be okay for our boat motors?? Just curious as to any specific feedback on that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 1:41am
I use Rotella T 15W40 in my boat, Allis Chalmers diesel tractor and my Dodge diesel Cummins. I buy it at wally world in the 2 1/2 gal size.
( The Cummins takes 11 qts.)I test it with Specto analysis and it is always around 1200 parts per million zinc.(that's a good #)
Gary I'll e-mail ya from work tomorrow that way you'll have my work e-mail.
- waterdog -
78 Ski Tique
daddyo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daddyo Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 1:42am
Mobil1 also lists their 15-50 with 1200ppm zinc/1300ppm phosphorous and specific use with flat tappets. VR1 lists at 1300/1400ppm and flat tappet use as well. The others? I couldn't verify the amounts. Shell used to list theirs and I remember it was in the 1300 range for the straight "T" weights. But that's no longer posted on their website, so a bit of a concern for me, even though that's what I'm using right now. Of course, the specialty racing oils are higher than both of the above if you do the research. I can't justify the higher price for those considering my motor is bone stock. PCM stated use any 15-40wt on their 351's when I asked them last year. I think I'll go with VR1 to be safe. The additives may be the best thing in the world, but they just don't pass my natural skepticism.
Post Options Post Options   Thanks (0) Thanks(0)   Quote daddyo Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 2:04am
PCM wants 15-40 and now the rotella 15-40 has been independently verified at 1200--perfect. That's what i'll be using. Thanks for that info, waterdog. If the levels change, let us know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 2:08am
Andy....Interesting stuff! I am glad to hear that. However, I was just doing a search on the issue of Rotella T oils and the straight weight vs. 15W40. I came across an article in the attached link on Ford Muscle Forums. One of the guys on there (N20mike...4th or 5th post down) gives a great overview and tutorial on oil ratings....ie....CI-4 vs. CJ-4, etc. Bottom line....he indicates Shell did "de-tune" my beloved Rotella T 15W40, and the 30W is the only one with the higher ZDDP rating.
Have you confirmed any of this in your testing yet?? Could it be that it is a relative new thing? Sounds like some of the old good stuff is still on the shelves out there but will be gone before long.
Ford Muscle Forums....Rotella T discussion
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 2:14am
Yes, VR1 and rotella are easily found. Until I see a comprehensive list breaking all oils down by ZDDP levels, I don't think anyone really has the full answer.
Yes, it's commonly known that the 15w40 rotella has, or had high levels of ZDDP.
As far as a napa seminar there are some questions. First, who sponsored the seminar? Were any oil companies sponsors? If so, it should make you wonder. Also, where was their data compiled from? Sources would be good. Lastly, while Napa is possibly known for being arguably better for knowledge than other auto part stores, keep in mind they are still an auto part store and therefore not the experts at all things automotive. Keep in mind that many auto store employees rotate from one chain to another. I have heard some ridiculous things out of my local napa employee's mouths as of late.
All of that aside,
2 questions arise that are huge. But obviously there are many other questions.
1, how much ZDDP is necessary for our motors to combat premature wear?
2, does using diesel oil with it's specific cleaning properties in gasoline motors negatively affect gas motors?
I've seen a lot of gasoline motors ( recreational and motorcycle) using rotella in them with great results to not worry about question 2. Yes, even in wet clutched motorcycles that are more picky about oils than our automotive based inboard motors.
Until we have the results of how much ZDDP is really needed, and what exactly every oil has in it for zddp levels, the best we can do is use the oil that we think is good, and has higher levels of zddp.
PAPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PAPA Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 11:18am
Andy, I tried to send you a email but it did not go thru. I would take you up on your offer to have the oil tested on my stroker motor to check for anything out of the ordinary. Can you possibly email me at partsil@suttonford.com    Thanks, John.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 11:31am
The oil lab here is standardized every 24 hrs and must pass a blind test of 4 samples every 30 days or we get de-certified. "Our" standards are strict "Aircraft Quality" "We" use 1000 ppm zinc as a thresh hold. 1400 ppm zinc is to much... In that sweet spot is where the maximum zinc preformance is. Diesel combustion is about as bad a thing that engine oil is exposed to.(Total acid numbers(TANs))
When we test ANYTHING in the materials lab it's indipendent, we do use manufactures spec's as as a starting piont/guide line but they have lot's on the line (contract's ect...) so we prove it good or bad.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 11:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 12:07pm
I'm not sure what's going on with the e-mail
Mine is andrew.owsiak@navy.mil
Gary,
     I sent you an e-mail but it got kicked back
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 12:41pm
Andy;
If I sent you a sample of the 15W40 with the CJ-4 rating, and the straight 30 WT as well, could you test those? I think it would be interesting to do a direct comparison now that the ratings are changing to see how much ZDDP is really in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2010 at 2:13pm
David,
   Sure, I don't need much, a small bottle with about 4 coke-a-cola cap fulls. Take the sample "mid-steam". Take 1 from the bottle as a base line and 1 from your warm engine. (It takes longer to write the results down than do the 45 sec. test)
- waterdog -
78 Ski Tique
