Lead plates in 94 Sport Nautique |
kirkgolf1
Newbie Joined: July-07-2009 Status: Offline Points: 26 |
Posted: September-27-2010 at 4:02pm |
Hello everyone. My father and I are the new owners of a 94 Sport Nautique. We are primarily skiers and were looking for a good family/ski boat. Here is the problem. I think the previous owner was into wakeboarding and has put lead plates in the transom. The problem for us is that it produces a rooster tail from 28-36 mph that makes for a tough transition even on edge. Does anyone know what the best way to remove the lead would be? I have some pictures if you want to see.
Mike,
The pictures are pretty small and I can't quite make out what's glassed into the hull bottom. Are you sure they a lead weights and not just a repair? If they are weights, you'll need to get in there are grind off/cut whatever is holding them in. |
kapla
those are not lead plates...they are sound dampeners bars glassed to the hull sorrunding the log and strut area..they are made of some heavy type of plastic or rubber...
my 92 also has them you can see them in this picture edit: not glassed..they are glued.... |
<a href="">1992 ski nautique
eric lavine
Kap, I to see those in the 92 hull i have...surely not lead
michiel200
Senior Member Joined: August-17-2009 Location: netherlands Status: Offline Points: 101 |
+1: my 1992 Barefoot has the same bars.
'92 BFN
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1750 |
Is that what CC calls Iso-damp? It was available as on option on my 93.
kirkgolf1
Thank you guys for the info. I feel much better now.
The only problem is that I guess I will have to learn to deal with the wake the way it is for slalom. Thanks again, Mike |
skier12
Newbie Joined: June-09-2007 Location: Hartford, CT Status: Offline Points: 35 |
Try adding some weight to the bow of the boat it seems to soften up the wake and it really improves the handling of the boat. I usually add about 150 lbs.
kirkgolf1
Are you running a Sport Nautique also skier12? What line length do you typically run?
Thanks for the suggestion! |
