Airguide Speedo Restoration/Repair |
Author | |||
Alex47
Senior Member Joined: November-11-2010 Location: Tarzana Status: Offline Points: 136 |
Posted: November-28-2010 at 12:14am |
Passing along some helpful information.
If you need your "classic" Airguide Gauge repaired or restored, Dean from Classic Boatworks does an excellent job. I just had one of my Airguide Speedo Gauge's repaired for $75+ shipping. Here is a link to his website http://www.classicboatwork.com/classicparts/gauges/gauges.html Classic Boatworks 1201 Meadow Lane Roseville, CA 95661 Phone: (916) 828-2014 "Dean" Note: This is a picture of the gauge I had repaired. However, he can completely restore your gauge to "like new" condition. |
emccallum
It costs very little to replace the glass, paint the needle, and replace the rubber grommet. Someone here has repro decals for the guages as well.
adamt
Gold Member Joined: July-18-2007 Location: Orlando, FL Status: Offline Points: 927 |
Here's the Airguide decal $10.00
-Adam
1973 Skier |
JMurph
Gold Member Joined: January-06-2006 Location: Maryland/NC Status: Offline Points: 738 |
I just had the white ones made also. For a $10.00 (ea) donation to this site I will send you one. I had them done with a slight color on the background, since no one could confirm that they were ever pure white. I did have one done in pure white and it was a little too sterile. I will eventually create a separate post for these in the For Sale section. |
76tique
Senior Member Joined: April-12-2009 Location: Nyack, NY Status: Offline Points: 226 |
John, I would like one of the white face decals. Really great that you had these done, this site is such a fantastic resource! Donation on the way...Where can I email you my address? I must be CCF challenged, can't seem to find your email on your profile.
- Tom thistle1678@aol.com |
JMurph
I'll change my profile to show my email. I'm so paranoid of spam that I hate to share anything on the internet.
john at summitabstracts dot com Just forward the donation confirmation with your address. |
Luchog
I need to reapair one, no chance on sending it to the US, it seems it's stuck and I cant see what should push the needle mechanism, anyone can guide me on this?=
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3887 |
Luch,
These units have a bellows inside of them that cracks from time to time. I have been told that a Jewlery Store can resolder the bellows. Water Pressure pushes the needle. There are several screws on the back of the unit that allows it to come apart. It is very easy to pull apart and to reassemble. I hope this helps, Donald |
Luchog
Donald, thanks for the answer, I have it apart already, I see what looks like a diaphgram assembly and it should push a little arm resting on it to move the needle. The needle mechanism is working, what doesnt is what is supposed to push it.
Donald80SN
Try to blow with your breath into the speedo. You may have to correct a rubber hose. This may help you to see what is going on. Compressed Air will break the bellows.
If I were you. I would look for another one on E-Bay. They come up on the USA E-Bay from time to time. You can switch out the internals or just use the entire unit. I need to get a extra one for this purpose. I was going to get both or mine recrommed, but I found some better ones on E-Bay and then sold my others on E-Bay. Donald |
This really isn't true unless you are using unregulated compressed air. The pitot is really supplying compressed air to the speedo. At 45 MPH, the speedo sees around 30 PSI. I'm mentioning this because I can't blow that hard!! If the bellows is cracked, silver soldering is the answer. Several here have even done it themselves. |
Luchog
could anyone enlight me as how does the compressed air into the below push the needle mechanism??
I have a rounded piece which I guess is the bellow you speak off, what's inside of it? I heard something looose when I shake it. |
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
Here are a few pictures of one that I had here at my house. You experts take it from here.
83Ski
jterr
Gold Member Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
I'm redoing mine and need the little rubber grommets. Any suggestions, can't get answer at the place in CA
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 931 |
My ace hardware has those rubber grommets in their specialty hardware bins. Look where the fasteners are located.
jterr
Thanks will check next time I go to town....
jterr
They had them
Thanks JT |
jterr
Here is the before:
and after: |
John,
Looks like the powder coat came out very nice and covered up the pitting. You mentioned your neighbor was going to do the powder. Does he have one of the kits that utilizes his oven or is it fancier than that? I've always been curious if the home oven powder coating works well. |
jterr
Actually this is paint, neighbor only had red or yellow powder. He mainly uses it for his bullets. If he gets Black will try on some thing. maybe the box for the foward/reverse lever.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10638 |
JT I think blue with an orange needle would be more in keeping with your "motif" |
jterr
The other one has a Blue needle
I like |
samudj01
Is that a sticker or did your face plate clean up well?
Also, what was your process for buffing off the putting? |
Why does your neighbor powder coat bullets?
jterr
Tried to get a new decal but the guy never answered me, so I cleaned with a soft brush then clear coated. Do not try and rub as you might remove the old paint. Very slooow grinding. |
jterr
Keeps from leading up the barrel. |
So now he has a plastic lined barrel? |
jterr
I guess |
SGreer
Newbie Joined: October-13-2021 Location: California Status: Offline Points: 8 |
I realize this is an old post but the pictures of the bellows from the hardware store are not showing up. Any chance anyone has pictures; I have 2 bad speedos on my sons 89 Ski Nautique. Thanks!
