  New Posts New Posts RSS Feed - shaking
shaking
JPirotte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPirotte Quote  Post ReplyReply Direct Link To This Post Topic: shaking
    Posted: April-17-2011 at 9:42pm
Always a boat story! Buddy hit something while pullling me yesterday. The prop is dinged up prety good, I have seen worse.The boat was shaking pretty good and the sterainf felt much different after. The shaft looks good the rutter seems fine very little play in it.
Could the prop cause this or do I need to worry about something else?
Thanks.
it is a 06 226 fyi
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2011 at 9:54pm
Jay,
A bent up prop can cause quite a lot of vibration but so can a bent prop shaft. I suggest checking the shaft as well. If you haven't seen the shaft alignment video yet, take a look at it. It has some footage of checking the shaft. Then, get the prop over to a prop shop for a tune up. If you don't have one handy, I suggest Delta. When you get the prop back, make sure you lap it to the shaft.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2011 at 11:18pm
Jay - We hit a submerged log last year & amazingly it bent the shaft but did not damage the prop. Had significant vibration.
I was able to straighten the shaft (had .009 inch run out) but had to remove it to do so.
Greg_SA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_SA Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2011 at 6:45am
I've also just gone through this would procedure... also check that the strut is not bent (check that the shaft is not binding in the strut bearing). Is the prop (shaft) easy to turn?
1989 Ski Nautique (SN2001)
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2011 at 11:24am
With my bad luck with prop damage I think I'm qualified to say... Absolutely, it can cause major vibration!! I would not run it if its causing a serious vibration.
Scrawford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scrawford Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2011 at 2:41pm
The Prop Shop just outside Seattle is great too. I just had my 4-blade fixed (wife hit the concrete boat ramp) and they had to straighten it, weld on material on two blades, then do a full polish. It was about $140.
Eric
97 196 Closed Bow
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPirotte Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2011 at 5:14pm
Thanks guys, I got my prop off and refurbished, Shaft looked fine but I took it in just in case.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2011 at 10:11am
this bent shaft reminds me recently of a shaft "which i normally normally wont do" its on a duo prop Volvo outdrive, it was out .065, i put it on v-blocks in the press and gave it a press, it popped right back within .0005, that was with one press on it.
i called the guy, which i drove 45 minutes to pull the outdrive, tore it down, complete reseal and air check, remember the seal kit was at a cost of 325.00 and will re-install with alignment. the boats value is around the 200k mark.
I told him it was going to be a thousand bucks....he *************** his pants and started giving me a real hard time, these are the guys that make me numb to working on boats,
I said you know what, look at it as how much I saved you, he got a price from the marina to do the job and it included a 972.00 new shaft, but wouldnt give me the exact figure. I dont know why i write this stuff, maybe just to give an idea of how much i hate the business end of thiongs
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2011 at 12:59pm
Maybe his budget only has room for the payments?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2011 at 11:53pm
he is playing with the wrong toys
