Need help with 2001 trailer bearing #'s.. |
soupbone
Newbie Joined: December-13-2010 Location: Tennessee Status: Offline Points: 28 |
Posted: April-26-2011 at 1:56am |
We had a great day on the lake, but a rough ride home.
I haven't had my boat long and have been doing routing maintenance on the boat itself. Well the bearings were on my list, but failed before I inspected them. Luckily the trailer made it home before the bearings completely let go, but it is in a bad spot (the very front of my driveway). Anyway, my internet search for bearing numbers has not been very sucessful. I now have the cups and races out of the hub, but I was only able to find a part number on the inner bearing cup which is a 29520. Can anyone help me out a little. I need to get this trailer repaired and moved asap! I need both bearings and the grease seal. Thanks |
84SN2001
Senior Member Joined: May-21-2010 Location: Ft. Bragg Status: Offline Points: 168 |
Go to tractor Supply Company or Home Depot to their trailer section and get new bearings! Just figure out what size the axle is and your good to go! Also go with marine high temp greese. Hope that helps a little
DIXIECHICKEN
Senior Member Joined: September-21-2010 Location: Texas Status: Offline Points: 106 |
Kinda the same thing happened to me, I went to my local trailer sales place(hub and what was left of my bearings and races in hand) They fixed me rite up!
GIG EM!!!
If its hurtin, soak it in cider!! |
Morfoot
Okay here are the NAPA part #'s I have for replacement everything for a CC trailer. Inner Bearing 25580 Race 25520 Outer Bearing 15123 Race 15245 Oil Seal 47017 Shane...Here is the link that Paula-Banana started in 2009 discussing the same problem.. Replacing trailer bearings on my 1988 |
84SN2001
Morfoot thaks for the part numbers, Im in Fayetteville. Well actually in S. Korea right now but when I get home on leave I've gotta square my trailer away before summer. Thanks for the numbers
Morfoot
Brian, first of all THANK YOU for your service and secondly your welcome. When you get home and need a hand with the trailer or a driver/pull give me a shout. We'll Go! |
84SN2001
Thanks to easy!! If you ever get a chance one weekend, head down to Lake Harding @ 20 miles north of Columbus. The Chattahoochie feeds it from Lake West Point. Awsome lake and you have to head north up river to the Amazing sand bar
soupbone
Unfortunately, those part #'s will not work on my trailer. My spindle is 1.25" on the outside and 1.75" on the inside. Thanks though |
anthonylizardi
Gold Member Joined: July-25-2007 Location: DFW, TX, USA Status: Offline Points: 836 |
I took my bearing to O'Reilly autopart and they cross reference them to some Mopar part.
soupbone
The problem I am having with that is I can only see the part # on the outter cup of the inner bearing. I really don't have anything to cross reference. I am going to take the outter race and inner dimensions to motion industries tomorrow and get them to help me find the correct bearings. The local parts stores have not yet been able to find the correct parts yet. |
