  New Posts New Posts RSS Feed - 95SN - Do I need a tune-up?
dillon5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillon5 Quote  Post ReplyReply Direct Link To This Post Topic: 95SN - Do I need a tune-up?
    Posted: May-24-2011 at 12:26am
Hey folks,
My 95 Ford 351 EFI is a bear to start, and even when it is warm it does not fire up like it should. When I am idling I tend to get fluctuations in rpms. Plugs were replaced two years ago. Any advice?
Thanks,
Charlotte, NC
95 Nautique 351
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2011 at 10:02am
wires, fuel filters?
mdvalant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvalant Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2011 at 11:19am
I have seen a lot of "fuel relay" convos flying around regarding the GT40. Is that something that can be checked first?
'90 Ski (sold)
'00 Sport
Mississippi River - Bellevue, IA
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2011 at 2:23pm
Just curious:
Is this a GT-40 with a distributor or is it a Protec ignition?
Also, are you sure you have good gas in the tank etc.? Any gas that has been sitting a while is always suspect with the ethanol issue etc.
wakeboardin2k4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2011 at 9:50pm
Initially I'd lean towards a fuel issue.
How many hours have you put on the boat since those plugs were done 2 years ago?
"I'm planning to bring my girl that rides on a trailer with me and leave my girl that complains about camping at home"
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillon5 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 12:29am
The gas is fresh.   Stored it on a full tank with stabil in it over the winter and have a fresh tank full in now. I guess I need to attack the fuel filter first, then maybe plugs and or plug wires. Less than 75 hours on the plugs though. Does this engine require "timing" or could my carb need cleaning? Just throwing some things out there for discussion. Thanks everyone. Finally figured out how to get my picture on the site.
95 Nautique 351
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 12:52am
is it carbed or EFI? you stated it was an EFI engine but then you say you have a carb and your profile says 285hp...
so is it efi or carbie?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 12:52am
You being EFI relieves you from the typical carb cleaning issues that older boats face.
Fresh fuel doesn't necessarily mean you didn't get bad fuel. Did this issue happen with the first tank and this tank or just this tank?
Start with the fuel filter. Does A 95 only have one filter guys? Never owned so not sure.
After that go for plugs. I don't think that's it but it's always a safe place to start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 12:54am
I'm pretty sure he's EFI. The picture in his profile has EFI on it so I'm guessing it was a moment of confusion and to go with the idea that he is fuel injected
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillon5 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 11:20am
Not a moment of confusion but a moment of ignorance! Remember I'm a newbie so bear with me. I think the fuel is good, so I will look at filter(s) first, then plugs and wires, then fuel pump I guess. Thanks
95 Nautique 351
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 11:44am
Mark, if you're still having problems with her then you could always take her to Ray City Marine and have the guy's there look at it for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 12:26pm
A 95 EFI 285 hp means he likely has a Protec, right?
How do Protec problems typically manifest themselves?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillon5 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 12:39pm
Guys - I'm not sure on the HP. I did not have my manual in front of me when I wrote it originally. I do know it is a 351 EFI ProTec though.
95 Nautique 351
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 3:49pm
Dillon, please take a minute on your time and go check the engine label, take a picture if possible. You are not helping us help you!!!
