My 87 Nautique won't start. |
Author | |||
PNALEWAJK
Newbie Joined: May-01-2009 Location: United States Status: Offline Points: 34 |
Posted: June-02-2011 at 12:43am |
I have a 1987, 2001 Ski Nautique, with a 351ci that I'm getting ready for the summer, but it won't start. It ran fine when I pulled it out in the fall. I've narrowed it down to there is no spark at the plugs. Going backwards, I cleaned the points, and have spark there now. The problem seem to be not getting spark out of the coil. If I unplug the coil wire for the distributor cap, and try to jump a spark off the coil wire.., I get nothing. I've cleaned the connections, but still no spark. I even pulled the coil out of my'61 Vette and tried that in the boat and got the same results...., nothing coming out of the coil!
I don't know what else to do. Anyone got any ideas...? Thanks, Pete |
Corvette Pete
Pete - What do you mean when you say you have spark at the points? They aren't supposed to spark. Maybe you have a bad condenser.
PNALEWAJK
Joe,
Of course there is spark at the points. Every time they open and close they will spark. That's probably voltage off the battery, my problem is that I'm not getting anything to the plugs... That would come off the coil... |
Corvette Pete
Pete,
Do you have a ohm meter with a pretty high range? Ohm out the secondary side of the coil. Yes, you will get a small spark at the point set but a bigger one if the condensor is bad!! BTW, SNobsessed is Chris and not "Joe"!!! |
PNALEWAJK
Hi Chris,
Sorry about the name. I wouldn't know what to look for as far as the ohms on the coil (not even sure what the "secondary side" is). As I said, I connected a working coil to the system, and that still didn't produce a spark when trying to jump it to a screwdriver. So, it seems like a bad connection somewhere... I know this has got to be something simple, but I just don't know where to look. |
Corvette Pete
Bri892001
For your reading pleasure:
http://www.jetav8r.com/Vision/Ignition/CDI.html I was hoping to cherry pick some wisdom out of that article and put it here but I find it all pretty confusing. There does seem to be some good info on points and the role of the condensor etc. |
Pete,
Is the point set opening? Remember you will only get the spark out of the coil when it opens up the ground side of the coil. |
PNALEWAJK
WOW...! Now that's information..! Perhaps a little more than I need, and a lot more than I understand.. However, it seems like everything points back to the condensor. So that's my next try. I'll let you know if I have success. |
Corvette Pete
Disconnect the condensor just to test for spark. It's only purpose is to protect the point set from arc erosion. If it's shunted to ground, it will have the same effect as the point set not opening.
identical problem yesterday, a little arc at the points from me manually opening and closing them and no spark at the plugs. the coil was the problem.
it will be one of 2 things, the condensor or the coil |
Rockster
Newbie Joined: May-02-2011 Location: Florida Status: Offline Points: 28 |
Run a hot wire to the +coil, and make sure the coil is grounded on the - side. If it fires up you will eliminate the coil. Did it to me last week the same problem and it was the condenser, brand new from Nautique. I have since done away with the points and now have the Igniter II w/ flamethrower II epoxy.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21116 |
Im not sure if youre describing how the coil should be connected, or if youre describing some sort of "test" to make sure its good, but either way, the suggestion is a little misleading. The negative (-) side of the coil shoud not be grounded, as it should be connected to the points. If the (-) side of the coil is grounded, it will never fire. |
skicat2001
Platinum Member Joined: November-24-2008 Location: Ft. Worth TX Status: Offline Points: 1950 |
Love points. Would not change a thang.. |
1985 CC 2001-SOLD
Lee Michael Johnson |
Lance, Looking at your engine pictures, it doesn't look like you went to a complete EI distributor. So, you'll love the conversion when it goes out on you in the middle of the lake!! I hope you carry a spare. |
Rockster
I have not installed anything yet it is still in the box. But in the EI description @ Pertronics basically it asked for distributor descriptionor numbers on the dist, meaning IBM 7008 prestolite. Not meaning to sound to stupid, this Igniter II is for this dist. I do not have to change the whole distributor do I? and as for the coil red is hot from the points to the coil and to clarify negative side ignition wires. The jumper direct from the hot on the battery is just a test wire for the coil. The engine should fire this way at least mine did, thus eliminating a defective coil and pointed me at the condenser. hope this is worded better.
Pete - How are you coming on this problem? Did you test the coil?
Lance, I think you should spend some time reading. Here's the link Brian provided. http://www.jetav8r.com/Vision/Ignition/CDI.html It will give you a better understanding of + and - wiring. Then, you won't confuse others! EI distributor conversions are notorious for failure. Some worse than others! As mentioned, if it goes, it will leave you stranded. With a point set, you can at least clean it up and make it back to the dock/ramp. A complete EI distributor is the route to take. However, what are you trying to gain getting rid of the point set?????? Have you done engine mods requiring the ignition upgrade or are you just thinking abot the "bling" factor!!! |
PNALEWAJK
Picked up a new set of points and a condensor today. I'll let you know if this solves the problem. |
Corvette Pete
Rockster
Sorry everyone, did not mean to misinform anyone. I do need to read closer. I was admitted to the hospital and truly expected to have all these parts installed when I originally posted, now they on the workbench. But this 14 day treatment has everything on hold. again sorry for the issue, thoughts from my brain to the keyboard don't come off so well. I'm new at this and just need to read and listen to all of you more.
Lance,
No need to worry. As you mentioned, most of the issue was probably in the wording. All you need to remember is the positive comes from the battery via the ignition switch to the positive side of the coil. The negative side of the coil goes to ground via the point set which opens and closes the ground energizing and de energizing the primary side of the coil. I wish you the best in you recovery. I hope they fixed you up. |
Rockster
The only reason I decided to go EI, is when we finally got back to the dock and my house we were not sure what we (my brother and me) did to get the engine to fire. all we really did was loosen the screw at the condenser pull the wire and then reconnect it and then she fired right up. not beng sure I thought EI would be the way to go. However my brother did say that points and condenser is a good system. As well I thought EI would be much more reliable. Guess not from what I'm reading.
Lance,
Your condenser must be bad and shunted to ground so you always have power to the coil. By disconnecting it, you allowed the current path through the coil to open via the point set. It's when the primary power to the coil is disconnected that you get spark to the plugs via the distributor. Read that link of Brian's. The only purpose of the condenser is to protect the point contacts from erosion by reducing the arcing when they open. |
PNALEWAJK
Interesting. So you're saying that if I take the condensor out completely I should get spark (enought to burnout my points if I leave it that way)at the plugs? What if I don't..? The new points and condensor didn't change anything. A couple of other thoughts have crossed my mind. I get 12v at the + terminal of the coil. I'm having difficulty getting a reading on the - side. Is it possible the the coil itself (the outer shell) is not grounded properly? ...or does it need to be...? The second thing is my battery is getting pretty weak..., is it possible that that would cause a weak spark ot the plugs..? Pete |
Corvette Pete
Pete, First, review the linked site that Brian posted. I took a look at it and found it's really a very good logical explanation of how a ignition system works. Lots better than I could explain in words!!! Yes, address your battery as well as all the cables and their connections. You need a good starting battery and good cables/connections before you do anything. As far as the "reading" you get off the - side of the coil goes, you are reading all the resistance of the primary side of the coil. Tell us more about how you are reading this?? (from what to what?) You should not be seeing 12 volts on the primary side of the coil. The ballast resister should be knocking it down to around 9. Again, tell us where you are getting the readings from. |
politicallycorrect
I would never imagine converting and electronic ignition to points...but if it came with points they are easy enough to troubleshoot. Plus I love feeling like Macgyver anytime I pull out the sandpaper and file the points and varoom! a running engine. |
PNALEWAJK
Hey Guys,
I don't know if this qualifies as a "Macgyver Feat", but it's running..! I don't know if it's the new point and condensor, the cleaning of the terminals, the weak battery or what.., but he's what I did to finally get it going. I gave up trying to follow the spark or the voltage. I re-connected everything, brought my wife's car up to the boat and connected jumper cables. At that point still no start. I then pulled two spark plugs and sprayed starting fluid in the hole. Put the plugs back in, and cranked the motor. While it didn't start, I got a couple of pops. That told me I had spark. I did that a couple more times, and it fired up. Thanks to everyone who offered help. It did keep me going, ad the boat is running now. One more question..., with the motor running, my voltage gague is showing -5 volts. Is it the alternator, the battery or both that need replacing...? Thanks again...!!! |
Corvette Pete
72 ski antique
Newbie Joined: January-29-2009 Location: United States Status: Offline Points: 18 |
Peter B.
I hope you see this. You ARE the guy with the answers. My question is generally in line with this forum topic. I'm not good with following the forum rules, cause I don't understand how it works...my appologies to all for that. anyway... My 72 Ski Nautique was repowered to a Waukeshaw 351W before I got it. I assume early 80s. It probably has less than 100 hours. I just bought a new Mallory magnetic distributor YLM554DV after messing up the original a few years back. It has sat dry for about 5 years. This weekend I got the distributor and coil installed. It started and is running rough. My firing order is not the same as a 351 Windsor that I look up on line 351W 13726548. Looking around the forum I saw someone call 18456273 a good order. Looking from the back forward my prop turns right. I'd swear my firing order is neither number above, but it runs and doesn't backfire up to 2000 RPM! It did back when, under power, so it is likely wrong. What to do!? Also, the Holley 9510 leaks like a sive. I assume a rebuild kit should help that. Sat too long, too dry? I seek wisdom and guidance. Thanks! |
Ski Antique
Randy,
Does the Waukeshaw have a ID tag on it to confirm it's rotation? When you say "turns right", you mean clockwise? |
72 ski antique
Thanks a million Pete for getting back. I don't know if I can read the plate, it is fairly crusty, but I will try. Even if I get a portion of the order that should help me match with one or the other! Yes, standing behind, facing forward, the engine turns clockwise.
I am digging around more on the Holley and I'm thinking that 9510 is not the model number. 2DJL-9510-E might mean something? If you have any clues on that I'd be grateful. I think I may have to bite the bullet and pay for the rebuild. Raw fuel is not a fun thing in your bilge! |
Ski Antique
72 ski antique
What's weird is I ordered a ccw distributor from Summit, becasue they didn't have cw ones on their site. I had to send it back. I would think most all single engines would spin clockwise. Twins another story, yet all they have for sale was ccw. My cw model was still in stock at Mallory so I could still get one. That is what has me nervous. I'm a GM Chevy small block kind guy. They spin clockwise. I will also confess that when I was messing with the distributor before, I thought I had a 351 Cleveland big block. SO that may be the order I used! Guess I'd better check that. My son wants me to get the boat to the lake on Friday, so I'm getting squeezed for time.... but that's me.
Thanks |
Ski Antique
