  New Posts New Posts RSS Feed - shaft seal
shaft seal
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Topic: shaft seal
    Posted: June-02-2011 at 1:34pm
I´m considering putting back the OEM shaft seal in my boat, as the one I have now is noisy IMO.
Some pictures of the codition of the seal, It only need new packing...only thing I see the output hole is little egged, due to shaft sitting low that caused wear.
Will that be a problem?
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2011 at 2:31pm
Seb,
You should be ok. I've seen lots worse and they still hold the packing in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2011 at 2:38pm
the safety wire, its purpose it to prevent the nut to spin loose?
I have none..what kind of wire I want to use there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2011 at 2:46pm
That's the idea but if you go back say about pre 80, they never had the holes for the wire. I've never seen one come loose!!
See if you can find a piece of .030 or .035 MIG stainless welding wire. That's what I use but I always have a spool of it in the shop too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2011 at 4:14pm
just for originaly purpose I would add it..lol
I also lack the shaft safety collar..but that one is little more complicated to find here...
I remember It used to be there when I bought the boat 10 years ago..but might got lost in the multiple times the shaft was out...
