  New Posts New Posts RSS Feed - 1994 SKI NAUTIQUE NO START COLD
QUEBEC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote QUEBEC Quote  Post ReplyReply Direct Link To This Post Topic: 1994 SKI NAUTIQUE NO START COLD
    Posted: June-16-2011 at 4:10pm
94 SKI NAUTIQUE HARD START COLD NO FUEL FROM FUEL INJECTORS ON COLD CRANK A TIMES. FUEL PUMP IS RUNNING HAVE PRESSURE, BUT NO TRIGGER FOR INJECTORS. ???? SENSORS PCM DISTRIBUTOR ANYONE HAVE ANY INFO ON THIS. RUNS FINE AFTER STARTS AND RESTARTS FINE ALL DAY
NEVER EVER GIVE UP ON YOUR SELF YOUR FAMILY YOUR FRIENDS AND GOD THERE ALWAYS A NEW DAY
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2011 at 4:59pm
Go into the reference manual section at the bottom there is a GT-40 service manual. I believe section 3 is trouble shooting.
There is a temp sensor (I can't remember which one) but it tells the computer the proper fuel/air mixture.
Section 2A17 is the theory of operation which helps understand how the sensors come into play.
mplummer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mplummer Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2018 at 2:59pm
I'm having the same issue with my 94 nautique, Cranks but wont start, no fuel from injectors, Once it is running, it runs great all day. Did you ever figure out what the problem was? Water temp sensor???
Thanks
Matt
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2018 at 3:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mplummer Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2018 at 3:56pm
Yes, but I don't have the gt40 in my nautique. I have the pcm 5.8 pro boss with a throttle body.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2018 at 4:05pm
Matt look at your fuel issue thread, I added something there
It may or may not be helpful.
