do I need an alignment? |
Posted: June-27-2011 at 9:56pm |
It's in the "new" section.
Tell Tom where it is too!!! |
drtybrdy9
Senior Member Joined: September-15-2010 Location: Wisconsin Status: Offline Points: 104 |
what happened to the video on alignment that i used to see on here all the time? could someone point me in the right direction?
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3889 |
Steve,
My two girls have not spoken about the tube this year. This is since we have been working with them on the boom. Donald |
emccallum
marty,
if you make the Official tube boat decal I will buy some! ernest |
"official tube boat" Marty start the presses
seen 2 airs and one master last Sunday, all three with tubes in tow |
Swatkinz
Platinum Member Joined: December-03-2003 Location: Lexington, SC Status: Offline Points: 1307 |
Donald, the girls are starting to realize that tubing isn't cool. the oldest is now skiing and the youngest is buckling under the peer pressure. I'm hopeful that this might be the last year of the inflatable in my boat. Thanks for all of the input fellas. |
Steve
Donald80SN
Steve,
Just do not beach it or pull tubes. Sorry but I could not help myself. I should leave you alone since you are now barefooting and got my daughter into knee boarding. Donald |
i would be retired by now if we didnt know about alignment, its just one of those things you dont think about, just like never getting pics of transmission shots....transmissions are the blacksheeps of the boating world
i will have to agree on this one. its the information age, and we have been informed
^IF THIS IS THE CASE^ (sounds like it is for Steve), I wouldn't bother checking it just for the sake of things. |
before 1982, they never talked about AIDS either
i just hate seeing MA trannys, costs me more to rebuild them
btw all those cases are pre-August 2007....the only ones i see nowaday's are newbie transmissions
If you dont have any real side to side or up and down play in your cutlass bearing, and your prop spins not just easily but uniformly smooth then run it like you stole it!
i use to strongly recommend it when the economy was good. lol
i was just going thru all of my spare cases trying to find some good ones, most were grooved from MA and i have to get them re-sleeved hw, you sure your not talking about getting laid? |
RainDog
Eric strongly recommends not checking alignment. He likes the additional opportunities to meet us face-to-face whenever possible.
Don't worry too much Steve, before Eric came on this site nobody really talked about alignment. We've never checked ours and it's been 10 years.
If anything being able to turn the prop that easy means your cut-less bushing is probably shot. Mine was pretty easy to turn but when I replaced the bushing it was much harder to turn without spraying some lube in.
I would disconnect the shaft and see how much play you have in the strut see if it's centered in the log and then if all is well just do a quick check with a feeler gauge. This is all assuming the boat is out of the water. |
Swatkinz
Admittedly, I'm trying to make myself feel good about not checking the alignment.
This was one of those "to do" items that never got done. I've never done an alignment before. I've had my boat for 1 year with little to no problems (pause while I knock on wood). I can turn my prop with one finger. Eric, Pete, et al, does the fact that it can be turned with ease mean I'm more likely to be in alignement than if it couldn't be turned so easily? It seems like if it were out of alignemnt, it would feel stiff and want to bind. Make me feel good about this. I know, I know I should just check it. I've been busy with work, life, kids etc. |
Steve
