  New Posts New Posts RSS Feed - is there an electronic Nuetral Safety?
trikeaholic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trikeaholic Quote  Post ReplyReply Direct Link To This Post Topic: is there an electronic Nuetral Safety?
    Posted: August-14-2005 at 6:24pm
is there an electronic Nuetral Safety on the Morse control? still trying to diagnose my engine that wont rev over 2100 RPM. Checked everything and still clueless.
1980 Ski Nautique
Ithaca NY
My Boat
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2005 at 7:30pm
Not that I am aware of!Safety?
Lack of power(rmps)Where is your timing set?
What is your top end...MPH ?
If the timing is retarded too much it will sputter and sometimes backfire...RPM's will be low. Coil and or resistor are often offenders too.
While running the engine , You can turn your distributer(advancing timing ) to where the idle is at it's highest rmps and continue until it starts to ping and miss.....back it off until there is little or no pinging...it will be close to where you want it and at that point for determining if you are getting higher RPM's.
Also...does it sound like it is reving more that the tach shows? Maybe the tach not reading correct?
Good luck and have fun once it's running right!
stang
The Super Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote trikeaholic Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2005 at 8:01pm
the original airguides show a little under 30 but really not planing out. its not a misreading tach, once 2000 R's come up, it wont rev, motor shakes and misses. Its all in my mechanics hands now. the last thing I can think of is it jumped time somehow. more gas you give it, nothing happens just wierd.
1980 Ski Nautique
Ithaca NY
My Boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote trikeaholic Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2005 at 10:43pm
Turns out it was the dwell, switching to a petronix tomorrow, see what happens.
1980 Ski Nautique
Ithaca NY
My Boat
