1979 BFN prop |
AnglersEdgeAJ
Newbie Joined: August-06-2009 Location: Rockford IL Status: Offline Points: 28 |
Posted: July-11-2011 at 5:27pm |
Hey all, thoughti had posted this a couple years back but couldnt find the post. I ve got a 79 barefoot with a 454 in it and have put a new dimension wake tower on it. Looking for suggestions on what would be a good wakeboarding prop for this set up would be. Any help is greatly appreciated.
AJ |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21115 |
Heres your old post: '79 BFN prop
Do you wakeboard exclusively? Do you run with extra weight? If so, how much? I would venture a guess that the Acme 1598 (13x14 3-blade, .080 cup) is going to be the best all around prop for the boat... but if youre running loaded most of the time, propping down to a 430 (13x13 3-blade) or 540 (13x12 3-blade) might not be a bad idea. You'll probably give up top end speed though. |
AnglersEdgeAJ
I do run loaded most of the time, approximately 4 guys, combined weight of about 1000lbs. And were 75% boarding 25% cruising. Not worried about top speed.
AnglersEdgeAJ
Oh yea and i was runnin a 13x15 on it.
The 13x15 Federal would have been the original prop. Going to a 13x14 Acme 1598 would only spin a few more RPM- its actually pretty darn close to being a stock replacement prop... but it would be a world better in terms of holeshot and speed holding compared to the old wheel.
So by "loaded" you mean that you only have 4 people in the boat? In that case, Id lean towards the 1598 or *maybe* the 430. If you were loading the boat down with a lot of ballast, then you may want something shorter. |
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
Before doing anything with the prop, kick out two of the guys and add a couple of girls. New combined weight of 750lbs will increase your overall performance (and the boat's). It will also make for a better day of boating. |
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
tullfooter
BTW
How's the boat running? I think that is the one bought here in Michigan (Flint). |
AnglersEdgeAJ
Thanks for the advice. Boat is running great! I have only had to replace the exhaust tubing and replace the shaft packing since i have had it. (other than maint. Stuff like changing the oil and fuel filter etc.)i will have to post some pics so you guys can see it. Its a totally different boat, keep an open mind though as im sure many of you may not like what ive done with it, but I Love it! When people guess the year of your boat and they guess 20 years newer than it is it puts quite the grin on my face. Pics up hopefully today
AnglersEdgeAJ
Couple more questions for you TullFooter and TRBenJ. What size driveshaft would my boat generally run(Trying to order the prop today but do not have access to measure the shaft)? And how the the rudder sealed through the hull? Is it just a seal on the vertical shaft? If so where can i find one to replace it?
Again, thanks for all your help! |
AnglersEdgeAJ
P.S. Posted updated pics on my "Diaries" post but they have not been accepted yet.
All of the props I mentioned above have the correct size bore for your 1" shaft. What are you trying to order?
The rudder has a packing gland, just like the driveshaft. |
AnglersEdgeAJ
Ordering a new prop today. Also want to order new packing for the rudder as when it is out of the water and i gently shake it side to side water inside the hull trickles out, so i'm assuming it needs replaced.?
What prop are you ordering???
A better indication of whether the rudder needs repacking is the drip rate youre seeing in the other direction (lake to bilge)... but its easy and cheap enough to do, and good preventative maintenance. The rudder port that CC tended to use (at least on my boats that Ive repacked) takes 3/16" packing material... but its not a bad idea to grab some 1/4" stuff just in case yours is different. Mcmaster sells the goretex stuff a bit cheaper than SkiDIM. |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13511 |
I'd go with the 430.
AnglersEdgeAJ
Ordered the 13x12 .080 acme. Going to run it for the weekend and order another prop next week for back up. Dependi g on how this one does will probably determine whether i will bump up one more pitch on the spare or not. Thanks again for all the help!
AnglersEdgeAJ
Hey guys, ran the new prop last night.(acme 13x12 .080) One word, amazing. Woke my motor like it had a fresh rebuild! No vibration at all, stands straight up and gets out of the whole with a full load about 3 times faster than it did before. Its running better than itever has since i bought it. Thanks again for all your help!
