  New Posts New Posts RSS Feed - oil consumption heavy
laurie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote laurie Quote  Post ReplyReply Direct Link To This Post Topic: oil consumption heavy
    Posted: July-17-2011 at 6:53am
guys need advice
2007, PCM 330 Done 550 hrs, recently noticed heavy oil consumption i.e oil level would read full then after 3 or 4 outings at 3300rpm , level would be at "ADD" . No noticeable oil leak (new pan) or oil in bilge, not checked spark plugs yet but boat runs fine. lots power and oil press seems ok (65 psi at top end speed).
some history, about 8 months ago changed leaky manifolds as I had water in oil
tx laurie
laurie
Post Options Post Options   Thanks (0) Thanks(0)   Quote laurie Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2011 at 5:06pm
could it be the pcv valve has anybody had probs with this
tx
laurie
Whitfield View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Whitfield Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2011 at 8:30am
Compression test?
Follow up with a leak down test if compression test comes up low.
Also look for cokeing on the spark plugs (as sign of burning oil).
Michael ....
I'm the black sheep ~ 1984 Dixie 299 Super Skier (350 Chev PCM / counter rotation / Velvet drive) Open Bow.
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2011 at 9:32pm
exhaust smoke colour?
Did you see if it's venting on the valve covers?
sounds to me as some broken rings.
