  New Posts New Posts RSS Feed - exhaust thru transom
boatnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boatnut Quote  Post ReplyReply Direct Link To This Post Topic: exhaust thru transom
    Posted: March-15-2004 at 3:16pm
The three inch SS pipes are cut at an angle.Would you turn them so the exterior face was verticle or so that they sloped toward the transom at the bottom?In the second case, the rubber exhaust gaurds would hang verticle which means open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boatnut Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2004 at 10:55am
Never mind. I glued/glassed them in so the long edge is at the bottom and the exhaust flap will sit against the pipe when at rest.
tryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2004 at 2:54pm
i would mount them so the tip is flush with the vertical plane. this will let the flappers seal the easiest.
