  New Posts New Posts RSS Feed - What size of shaft packing for '65 Skier?
JamesGang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamesGang Quote  Post ReplyReply Direct Link To This Post Topic: What size of shaft packing for '65 Skier?
    Posted: July-23-2011 at 7:29pm
Hi and thanks in advance to those who take the time to respond. I've searched the forums and cannot find what size of shaft packing to use for my 1965 American Skier. Is 1/4" correct? Any advice on putting it in? The boat has sat for ten years and water flows up and in pretty good when I put her in the water the other day. How many drips per minute is ideal? Thanks again.
J. James
J.James
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2011 at 8:01pm
I do not remember the size of the packing but here is what I would do. Unbolt the the coupler and remove it from the shaft. Remove the stuffing box from the log. I would go ahead and replace the rubber hose portion of the log if it has never been done. Mine crumbled when I removed it. Once you remove the stuffing nut you can pull the stuffing out. There will be 3 or 4 pieces inside. Keep at least one so that when you cut the new pieces you have a guide. Once you see how they are packed in there it is pretty straight forward putting the new back in. Just stagger the breaks so water does not have a direct path and keep everything nice and square.
Once reinstalled you probably will not have to tighten it very much at first. Mine drips 3 or 4 times a minute and stays cool. You want to find a happy medium between too many drips and getting too hot. You should be able to hold your hand on it comfortably. If you burn up the wax it will start to leak too much. May have to tighten after a few hours of use.
I think there are only 2 sizes of stuffing. Get both if your not sure. Its pretty cheap stuff.
Also might as well replace your cutlass bearing while you have the shaft apart. Especially if you have never done that before either.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamesGang Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2011 at 11:40am
OK, where is the cutlass bearing?
J.James
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2011 at 1:34pm
Its the rubber insert in the strut. You can get them at skidim.com.
1973 Skier
