  New Posts New Posts RSS Feed - how many hrs till i need to rebuild
brandon View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote brandon Quote  Post ReplyReply Direct Link To This Post Topic: how many hrs till i need to rebuild
    Posted: August-19-2005 at 12:53am
i am looking at buying a 1997 ski nautique that has 500 hrs is that to many hours? some tell me at 500 hrs it is due for a rebuild. the boat currently runs good but how do you know when you need to really get in there and check it out
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2005 at 2:01am
That sounds absurd. 1500-2000 hrs is typical, more if it was maintained well. A compression test is most indicative of internal condition.
River Rat to Mole
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2005 at 2:30am
Concur 100%.
400-500 hours is about average for 97. Anything less would be considered very low hours. Doesn't even begin to touch the lifespan of that engine.
BKH
Livin' the Dream
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2005 at 11:18am
A friend of mine has over 1700 hours on his '82 SN 2001 and it still runs strong. It's starting to show some signs of wear but probably still has a few strong years left in it.
As long as the engines are well maintained they'll last a long time. It seems a lot of folks have some sort of mishap that leads to an engine rebuild in much shorter time. Thinks like severe overheating from a blown impeller, bad winterizing and cracked parts, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2005 at 12:44pm
I agree. 500 hrs is nothing. Got a bud who has an 88' 2001 and has 2200 hrs on it and it still pulls like it were knew. He also carry's about 1800 lbs of lead and water weight with him too.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2005 at 2:32pm
well isn't 500hrs the recommended sevice hours for the prop shaft, in other word it would be time to replace the prop saft and strut bushings. But the engine is good to go?
mackwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2005 at 4:57pm
I would, if buying a used inboard boat, reguardless of hours, check output shaft bushing, replace raw water pump inpeller, change all fuilds (engine/trans) fuel filter, clean raw water intake strainer (if equiped) check trans cooler for restrictions (leaves trash etc.. in water line to cooler) Just commom maintenance stuff as you may not really know how boat was treated before you bought it. I have seen many engines with proper maintenance run over 2500 hours, and some with 300 hours be a POS
NO LONGER A MEMBER
Rosser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rosser Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2005 at 3:41pm
Most of us are understand miles.To get a good idea just say hours x 45mph will give you miles on engine if in a car.Not perfect,but close.Also,a marine engine does not have to deal with dust.Ever.500 x 45mph = 22500 miles.2000 x 45mph = 90000.I think this sounds about right if you change your oil.
1971 Skier holman&moody 1971 Mustang holman&moody
cc View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote cc Quote  Post ReplyReply Direct Link To This Post Posted: August-24-2005 at 11:43pm
The first PCM 351 in by boat was replaced @ 2300 boat hours,the second 351 was pulled @4993 boat hours and overhauled.Both were still running when taken out but were down on power.
The first motor was stripped and rebuilt requiring
rings-original pistons reused
bearings
2 exhaust valves
new lifters,cam and timing chain
That motor went into another boat and is still running fine 5 years on.
The second engine was stripped and rebuilt,
exactly the same scenario but required 4 exhaust valves,this engine is still running strong 730 hours later,the trans was fitted with new seals. The hull has 5700 hrs and is still fine.Both motors have heat exchangers and the boat was used commercialy only in salt water.
How??
Great product!
Maintainence,Maintainence!
150 hr servicing,filters oil ect
Clean dry bilge
The engine is set up to run at a contiuous hot operating temp, not fluctuating hot and cold and the boat is used not abused!
500 hrs on a 97 CC if its been looked after its barely run in!!
88skisupreme View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88skisupreme Quote  Post ReplyReply Direct Link To This Post Posted: August-25-2005 at 12:52pm
on the other hand you have to remember that disconnecting the wire or a bad fuse can shut down the counter. You see a lot of early 80's inboards for sale that claim 300 hrs.
Not saying that that boat is inaccurate but I recently looked at an 82 that was supposed to be under 400 hours and it was beat. I'd bet it had over 2,000
