World Record Attempt This Weekend |
Post Reply | Page 12> |
mdvalant
Grand Poobah Joined: May-06-2009 Location: Bellevue, IA Status: Offline Points: 2059 |
Posted: September-16-2011 at 2:48pm |
Hey all,
Wanted to share a little fun... This Sunday I'm invited to ski in a world record pyramid attempt! The plan is to try FIVE 4-highs behind one boat (60 people) If that goes well, we'll try 6 behind one boat (72 people) Main tow boat is a 22ft dyna-ski with triple 250HO Etecs. This boat will NOT pull us all off the dock so we will be doing a tandem boat pull. One boat in front of the other...once we get off the dock the front boat releases from the rear boat and gets the heck outta the way. Should be fun :) Video of current record |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6107 |
GOOD LUCK !!!!
What a great time. Wish I could be there to see it. |
Hollywood
Since when are they letting Iowa teams in? LOL.
I don't think there is a 22'. I know he has a 24' flat top he is thinking of putting 4 engines on though. You are probably thinking of the more common 20'. How far behind the boat will you be? |
mdvalant
It's dyna-ski not the dyne
They are two different makers and the ski is 22ft, the dyne is only 20ft no idea on any info other than what boats and what time I need to show up lol |
Hollywood
mdvalant
Do you believe everything you see/don't see on the internet Hollywood?
One sec, I'll get more info on this boat in a few |
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
Good luck from Spray Masters!
What team/who is hosting this? |
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
mdvalant
Backwater Gamblers are hosting!
Five Seasons Hartwick Huskies Rockford Ski Broncs Waterloo Waterhawks Thanks Spray Masters! |
Hollywood
Take a look at what pitch props they put on there for that too.
A little rivalry there, nice. Who were the 4 teams from last time? |
mdvalant
Doing it on the Rock River at Backwater's home site. Not sure about the jump, and they run 15pitch props on the triple...which is usually the standard in show skiing
sweet77
Gold Member Joined: January-06-2011 Location: Florida Status: Offline Points: 666 |
Man that is awesome I would love to be apart of that seems like a good group good luck
mdvalant
From the boat drivers daughter/show director
"the triple rig? it's a 22ft dyna-ski with triple evinrude 250s. " |
Hollywood
I think someone might be a little off. Nevertheless, take pics and good luck to you all!
mdvalant
Boat is brand new this year. It was at think tank in WI. Were you there? It's 22ft, I have touched it. It was beautiful. Noticeably bigger than the other boats. Good friends with Brint (the driver)
I can measure it and take pics this wknd if you want me to ;) |
C-Bass
Platinum Member Joined: November-18-2008 Location: Columbus, IN Status: Offline Points: 1248 |
Yikes |
mdvalant
Hollywood I stand corrected. I emailed dynaski.
"t is 20' 1" long. The running surface is about 8" longer than the older style boats." Sorry, always adding length to things... Muhhaha |
Hollywood
Well if it's a brand new boat then that explains it. I've never been to a think tank. Perhaps this is the 24' shortened? The beam on the 24' is a 1' wider than the 20'.
Edit: bow down... They basically pushed the transom back, the "fins" on the sides are still the longest part of the boat. |
mdvalant
I'll talk to backwater more Sunday to verify. So weird though cuz the boat seems so much bigger than the 20s.
Mike,
Go for it and good luck on the attempt! You mentioned another boat pulling the triple until everyone's out of the water or off the dock. Do you know what they will using for the front tow boat? |
mdvalant
The front boat will be one of their 20ft hydrodynes with twin 225 optimax mercs!
They have perfected the tandem boat pull over the years, pretty awesome to watch. I'm excited that I get to ski behind it! |
Do they use a standard release like a ski rope release or is it something more HD? |
mdvalant
Long story on the tandem boat set up
The main tow boat, in this case their triple rig, has a hole on the top shell of the boat right in the nose for a large metal rectangle shaped object with a hole in it to slide into. That hole is for a pin to go up into and hold it in place. The pin is powered via a scuba tank/pressure (an engineer would be able to explain this so much better) On the other end of that rectangle chunk of metal is the rope to the lead (helper) boat. When the triple driver knows he can pull the pyramid he pushes a button, you hear a small air brake type sound, pin pops out and the front boat speeds away with the metal piece and rope in tow. It's a pretty killer system to be honest. wish I could explain it better for you, hoping I'm getting the point across. Long story short, NO, not your standard quick release :) |
mdvalant
I'm awesome at paintshop
Mike,
Got it - thanks! As an engineer I understand and you did a good job explaining the device. It's a pneumatically operated cylinder that pulls the pin so the thimble or clevis on the end of the tow rope is released. |
mdvalant
Pete's got it! haha glad I was close enough! :)
75 Tique
As long as you don't hook it to the lifting rings, you know those are just for lifting and not horizontal stresses, right?
mdvalant
I wouldn't be surprised if we broke some stuff Sunday!
dmiracle
Senior Member Joined: July-22-2008 Location: Johns Creek, GA Status: Offline Points: 300 |
With an ultra high end flux capacitor. |
Doug
Hollywood
Weird, their old boats are Tom Miller Dynes with Mercurys.
mdvalant
Yea Hollywood, they finally went the correct route with their new one. They bought the evinrudes outright, but are still sponsored by their Mercury dealer. I thiink their Merc dealer sells Rude too though...
Either way, slowly but surely they will convert to all Rude I'm sure. |
