454 manifold |
4woody
Groupie Joined: August-19-2011 Location: forney ,tx Status: Offline Points: 58 |
Posted: October-08-2011 at 4:21pm |
does anyone no were i can get a cheap pcm exhaust manifold R028010..I broke 2 bolts off and really f...up one of the bolt hole once I started drilling on it
Bri892001
I don't know about cheap, but skidim and nautiqueparts have them.
My Correct Craft Parts seems to have the best price on them. |
4woody
thxs for the info ..I was looking at the riser an the inside of it looks like their was another chamber but it is rusted out should i replace it as well.
Bri892001
I'd say it's a good idea to replace the riser as well, those are also available as separate parts.
Make sure you install the manifold to riser gasket the correct way. By design, the gasket is meant to intentionally block one of the passages. Ski dim says that it's the passage closest to the exhaust outlet. |
4woody
thanks again for your advice..this my first skiboat ever ..
Bri892001
No problem, hope it goes well. There's tons of info in the Boat Maintenance and Engine Maintenance boards on this site as well.
