boat Finish |
Fournier
Groupie Joined: August-12-2009 Location: Ma. Status: Offline Points: 40 |
Posted: October-22-2011 at 8:24pm |
I have been using 3M restorer and wax for my 86 Ski Nautique.
Being told that Poli Glow does an excellent job. Want to know if anyone can back that rumor up. Thanks, Ross |
NAUTI84
Senior Member Joined: June-10-2004 Location: United States Status: Offline Points: 485 |
PoliGlow has good reviews within the RV forums.
But then I started reading about RedMax Pro Floor finish. Way cheaper - Did my motorhome with it and it came out great! Google it on RV & Boaters forums and you'll get loads of info. Now - I'm not so sure I would've had the balls to try it out on my old Nauti though???? I always just used NuFinish with decent results. |
As I understand it, Poliglow is an extra material that you put over the surface of the gelcoat, which gives off the appearance of having a "restored" finish. Sort of like a non-permanant clearcoat.
It is NOT an appropriate way to restore the shine... to bring back faded or chalky gelcoat, smoothing the gel and removing the surface contaminants (by buffing, or if needed, wetsanding) is the right way to do it. Poliglow is probably easier, but the finish will not last- it is a shortcut and a band aid at best. Once you complete the wetsanding and buffing, the finish needs to be protected with wax. Keep it out of the sun as much as possible, and it will last a good long time. |
storm34
Grand Poobah Joined: November-03-2008 Location: Dexter Iowa Status: Online Points: 4492 |
Tim's right guys. Take a look through the thread below and see Tim's more detailed instructions on wetsanding and the buffing process required to bring back the gel. Results are great!
Which 3m product? |
NAUTI84
Tim's correct. The Poliglow & RedMax are like a protective coating. You build it up with lots of thin coats. But the surface underneath needs to be clean and in decent condition, as you are just kind of encasing what's underneath. |
Randy_in_Ohio
I agree with Tim. You really need to use a buffer and possibly wet sand to get down to the shine.
finish with a wax that contains UV protection. a lot of the car wax does not have this and doesn't need it because of the clear coat used on cars today. I have been using Meguiar's Flagship Premium Marine Wax once a year since buffing mine out over 5 years ago and it still looks like I just buffed it. |
Randy_in_Ohio
I've also been using this stuff every time I pull the boat out of the water and wipe it down. Use it on all my cars too. I love this stuff. Makes everything look like it was just waxed and keeps grime from sticking making it easier to clean or in the case of the boat, wipe off the lake scum.
PDP Body Gloss |
Don't be encouraging Tim you guys, thats not keeping it original
In the post with the 69 brochure one of our new members has posted this page,look in the center column,you just need a hose! |
Fournier
That's what I like...no stone left unturned! Thanks for the responses.
Ross |
You wouldn't see a boat ad with someone standing on the doghouse today!!
Gary, that ad may have been written when CC had 43 years of boat building experience... but its pretty obvious that they only had 7-8 years of fiberglass, gelcoat and foam work under their belt!
By the way, Mr. Thrower (aka nautique frk) is far from a "new member"... you'll notice he joined here a few years before you (and I) did. Check out the diaries- he has quite the impressive CC collection. He is the source for more than a few brochures in the reference section as well! |
ny_nautique
They also seem to have had even less copywriting experience under their belt. I can't wrap my head around the sentence that goes from the left column to the center column: "CCs total approach starts with the firberglass used in the hull - our recipe is scientifically controlled for the greatest strength - curing is complete." Huh? |
- Jeff
1999 Ski Nautique |
ny_nautique
With the boat in gear, the driver leaning on the throttle, and most of the weight distributed to the stbd side. |
- Jeff
1999 Ski Nautique |
Jeff,
In the early days of fiberglass, some boat builders were having problems with improper cures. I understand it was due to bad mixing and or a ratio problem with the resin and catalyst. I have a feeling this was what CC was trying to communicate. |
Thanks for pointing that out Tim,I assumed by the post count Mr Thrower please accept my apologies and I thank you for your contributions. |
On further review Tim, it turns out the item I refered to was a magazine page ad posted by relatively new 5-11 member, Mountaineerminer.
Thanks to both him and Mike for posting those hard to find '69 items. |
