brass freeze plugs. |
Post Reply | Page 12> |
Author | ||
lineman458
Senior Member Joined: June-14-2011 Location: Ethridge ,TN Status: Offline Points: 121 |
Posted: November-02-2011 at 11:12pm |
Is it necessary to put brass freeze plugs in a inboard 302 engine?
If so what is the reason? |
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
I think it is a good idea so you dont have to worry about them rusting out
83Ski
Randy_in_Ohio
I think they use brass on marine engines because it resists corrosion better than steel.
I had one steel freeze plug in my block from the PO... Eric replaced it with the proper brass plug when he did my tranny. So, it will work, but they should be brass. |
Randy_in_Ohio
Don, you beat me by two minutes!
So why don't they use brass on all engines? I'm sure an engine block in Ohio gets plenty of salt water on it during the winter. |
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3238 |
Because automobiles run antifreeze with corrosion inhibiters. Freeze plugs rust out from the inside. Some race cars use brass because they don't run antifreeze. |
eric lavine
once again, mislabled, for those who dont know and yes being redundent, they are refered to as freeze plugs. but the purpose of these plugs are to plug the hole where the sand is drained after they are casted at the casting plant...
and a good thing to point out is with the brass, if you bake the block be sure you remove every single one of them because they shrink from the heat...or you will be pulling the engine again |
nautique frk
Platinum Member Joined: February-16-2004 Location: United States Status: Offline Points: 1784 |
Eric, I have alwas known them to be casting plugs not "Freeze Plugs"
lineman458
Yes I understanmd the purpose of the round discs in the block where the casting sand is removed,I have always heard them called freeze plugs.I could care less what they are called or why they are there I just want to know if I "HAVE" to replace the steel ones in my block with brass ones.
lewy2001
In the southern hemisphere we call them welch plugs. Maybe because freezing is never an issue.
Steve, There are many threads discussing those damn little round things in the sides of our blocks but it's not a port for removing sand. The hole is there to support the inner casting core. No big deal, since we all know what you are talking about!! The damn 'freeze" plug I feel was placed on the "core plug" many years ago when people found them pushed out when the block froze!! Yes, go into Autozone, and ask them for a "core plug" |
dwcar
I dont think you have to replace them unless they are leaking. You might buy you a couple for your tool box if you are worried.
83Ski
critter
Platinum Member Joined: January-11-2008 Location: New Hill, NC Status: Offline Points: 1227 |
As was mentioned in an earlier post. The only real worry is that they will rust from the inside out. This can take a long time so if you
plan on keeping the boat, replace them with Brass so you do not have to worry about them anymore. If you plan on selling the boat in 5 years or so, they should be fine. Rusty, but fine and the next owner will probably replace them. |
1980 Ski Nautique
1966 Barracuda |
For some reason I never seem to get them for my heads.My 1st set of heads the shop forgot or I forgot to tell them.They did put them in the block. Anyway they lasted about 10 years before they leaked.When I got the P's I asked for them but didn't get them either.I'll change them when I need to since their alot easier than the block to do.
eric lavine
Lineman, i feel if you know what they are, maybe you could tell us brass or steel???
closed cooling, steel lake cooling, brass I threw 2 BBC's away yesterday, 2 plugs pushed out on the blocks, 2 big cracks down the valley..thats why i get upset when they are called freeze plugs, maybe once out of many without corroding, have i pushed a plug back in and it didnt fill with water. just passing info, I dont care what you want to refer to them as, but to me they are cast plugs. so, steel on closed cooling because antifreeze does not corrode them, all other applications with water flow through block, use brass I had my once a year conversation with another boat dealer, he stores a couple hundred boats, they actually can hear the blocks snapping outside of their shop on the ones that prefer not to winterize |
lineman458
Just once I would like to ask what time it is in this forum
without having to get a broken down explanation of how a watch works. |
Mojo
Grand Poobah Joined: December-06-2006 Location: United States Status: Offline Points: 3104 |
Hahahahaaa, thats gonna be tough |
05' SV211 TE
eric lavine
daddy told me once that you just dont stick in there, now i know why
eric lavine
I found a complete explanation on this site, is needed, especially when I talked to a guy who changed his 4 spark plugs on one side of the engine and didnt realize that there was 4 more on the otherside, maybe excuse the ornaments but i think it is necessary
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21131 |
Youre right... not only did you get a great answer to your question, but it spurred an interesting discussion. I think anyone who added extra information owes you an apology! |
I'm sorry. BTW, what time is it? |
Hollywood
What zone are you in? Who's on first?
eric lavine
he did say you gotta lick it too, no he didnt, i figured that one out on my own
Randy_in_Ohio
C-Bass
Platinum Member Joined: November-18-2008 Location: Columbus, IN Status: Offline Points: 1248 |
I understand where you're coming from, but I also appreciate a detailed response and explanation. It's easy to just get the answer and move on, but if you fully understand the problem, and how the answer was derived, you'll probably never need to ask again. Obviously there are times when just the answer is all you need though. |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6107 |
Eric, I'm not sure of the context of your remark unless its related to this little anecdote: What do a 17 year old girl and a 9 volt battery have in common? You know you shouldnt lick them, but you do anyway. Hollywood: I am deeply saddened that you have sold my boat already, especially after it went from me to Tim to Chris to you so quickly. Tho I do have to say that reverse gel is a beauty. I really like those. If now had been the right time, I would have given serious thought to Eric S's. |
Hollywood
Yeah but mine's a big block.
75 Tique
Speed run: 2010 Northwood Lake
Eric Svensen Big Block Nautique 50.4 Larry Hineline stock small block chevy 50.7 just sayin' |
Hollywood
I'm looking for a Sidewinder banner for my basement, do you know where I can get one?
75 Tique
Oh, yeah, sorry. 2:09. |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5772 |
So here's a picture of my first boat. Starcraft with a 90 hp tower of power.
oopps! Sorry I thought I was in the 2012 CCf calender thread!!! |
