  New Posts New Posts RSS Feed - Correct glue for Carpet Trim
AussieNorts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Topic: Correct glue for Carpet Trim
    Posted: December-07-2011 at 1:46am
Hi guys, I am just enquiring here if anyone has thoughts on appropriate glue to adhere the carpet trim to the fiberglass floor substrate? The contact adhesive I am using for the carpet does not seem have enough `grip` for the trim. I hope someone has some experience with this. Once again thanks for the help guys.
Correct craft.....is there any other boat?
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: December-07-2011 at 6:07pm
Hey Aussie,
   "henry's 263" has been the recomendation here in the past.   I am not sure where to get it, but the lesser grades are not waterproof, so you'll want to shop around til you find it :)
Chopper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chopper Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2011 at 11:09pm
Steve,
What are you using.?
I've never had any dramas with contact adheasive as long as it's applied correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2011 at 11:20pm
Chopper,
I have gotten myself a tube of Sika automotive adhesive sealant (the black super sticky stuff) just would be a little messy i think. I have not stick the trim down yet. I have the carpet all in there and it layed flat just not stuck down. The Henry`s glue that has been mentioned here is not available in Oz (as usual. So your contact adhesive your using do you have a brand name? I am using a drum that an upholsterer friend gave me. It worked great on the carpet.
Steve
ChristinesMarine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChristinesMarine Quote  Post ReplyReply Direct Link To This Post Posted: December-16-2011 at 11:55am
We use Weldwood HHR contact cement to glue down the rubber carpet trim and have not had a problem in 30+ years.
