boat paint |
ross946
Newbie Joined: September-04-2011 Location: florida Status: Offline Points: 20 |
Posted: December-09-2011 at 9:41am |
Hello, its time to paint my 78 fish nautique I have a couple of questions and I am looking for some help . There are alot of different paint brands out there I am looking for some input on which one is the easiest to use and gives the best results, also as far as sanding the boat how much do you strip it down etc. what is the best way to remove bottom paint as well thanks in advance for your help Ross.
harddock
Platinum Member Joined: June-04-2008 Location: Toontown, MA Status: Offline Points: 1763 |
Most people here will strongly suggest re gelcoating the boat, but if paint is what you want then Awlgrip or imron are the usual paint of choice for fiberglas boats.
Ross,
How bad is the original gel? Can it be wet sanded and buffed? Many here have had great results with the process. Paint will not hold up like gel does. |
ross946
It looks like boat was painted once the finish underneath the paint looks better than the paint itself.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21118 |
In that case, you may want to consider stripping the existing paint and see what youre really working with before making any decisions on how to finish it. |
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3236 |
Not that I am a guru on this stuff, but I'm with TJBenj on this. You will need to strip the old paint to assure a good paint job if you decide to go that way, so give it a try and see what you have. Wet sanding, buffing, and polishing can do amazing things to gel coat. It is so much nicer than paint.
Good Luck! |
1970 Mustang "Theseus' paradox"
If everyone else is doing it, you're too late! |
The only thing I might add is that it most likely is a saltwater boat that might not have had the loving life that a northern boat that had been put away for 5-6 months so it might have been painted to make look nicer.Also he'd have to do it by machine,doing a boat that size by hand might make his arm fall off
