Not another Mustang restoration thread. |
Post Reply | Page <1 4950515253 54> |
John,
Continue on and stay safe. |
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1181 |
Keep calm and carry one. It’s fine to post your hobby Turn tv off |
skutsch
Yes John, it is a good escape for all of us. It is a small sense of normalcy in this time of unknown and craziness. So continue to work, continue to post and of course, wash your hands - HA!
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3236 |
I haven't been motivated the last several days, but I got out to the garage last night and masked the engine. I made a little spray booth from some furniture packing material from my daughter's business and gave it a rattle can job today. It's acceptable. A lot more parts and the exhaust manifolds left to do.
I got to thinking about the crank and cam I saved from the sacrificial H/M Mustang, The block was cracked and evidently not original. The area where H/M would have stamped the number matching the data tag was blank, likely an indication it was a replacement engine. Most often people buy a short block which includes the rotating assembly. I am now questioning if the spare cam is an H/M cam, or more likely a standard RR replacement. I should have had the machine shop that rebuilt my engine give me the specs on it for comparison. A bit late now. I hope everyone is well. |
john b
The main stringers are pretty much done, on to shaping the secondaries. They are 100.75" The coosa is 96". I believe the length was only important to pick up the last crossmember for a seat anchor point, which they missed from the factory. I'll add on a bit if I feel the need once they're in.
I am laying out the pieces for fitment. The removable panel has 1/4" plywood backing over about 1/2 of the bottom. The stringers are shaped to allow it to be the same height as the pan without a floor and I think that is the reason for the skinny backing. It has a 1/4" bow in the center. I think the easy way to do this is to chisel the plywood off of the removable pieve of the fiberglass pan and bond it to 3/4 coosa all the way to the tail for rigidity. I am apprehensive. I would hate to do damage and need to call the Seadek guy. The pan is worn at the chafing points but I still like it. This Mustang will be a "driver" when it's done, but I have a lot of love for it. I debate sending the Velvet Drive out for a freshen up. It hasn't been used in 20 years. I started the boat when I got it about 9 years ago and it shifted properly on the trailer and had a clean neutra.I I lean toward dropping it in and rolling the dice. At least it's easy to R&R if it has an issue, but I would probably lose weeks looking for a rebuild . |
Order your self one of these from Harbor Freight cuts good and won't get away from you. I know Pete will tell you to buy the original expensive one but this one works and it's 20 bucks. Throw it away when your done
My hatch was plywood cored- real spongy. Cut the top fiberglass skin off- Then cleaned up all stuck on remnants using the tool like a scraper this was end result- Finished with new plywood- |
john b
AHHHahahaha
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21116 |
What is that thing?
Backing the entire panel with some Coosa is a good idea. I’m sure CC only backed the part of the panel that would get stepped on with the back seat in place. I would put the panel face down on a flat surface and add some weight when bonding- might get that bow out. The patina on the floor pan will not hurt it’s appeal. I would take a chance on the transmission also. |
https://www.harborfreight.com/Oscillating-Multi-Tool-62866.html Although I do prefer a higher quality one, due to the heat and vibration the cheaper ones have. |
OverMyHead
You can get the Rockwell version for $79. Has some decent weight to it for the price. Weight seems to be the key to keeping it stable.
1987 Ski Nautique |
Ah, I’ve got a PC version. Still discovering new uses for it. Didn’t recognize it with that half round blade.
If the wood on the back of the panel is rotten I’d be going after it with a flap disc on an angle grinder. |
Or just use the tool it's like skinning an animal,less mess as well. I originally bought this tool to remove carpet- that literally was like skinning |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10680 |
I think the lady down the road has one of these tools.
It's cordless, variable speed and takes lots of different attachments. I think she likes it, she's always smiling |
Best Christmas gift I ever got my wife! Now I can spend more time in the garage with my toys and she still smiles. |
john b
I layed out the patterns taking into account the unplanned backing the removable panel with Coosa, and I'm not sure if I can get by with just one more sheet. . I may need 2.. As long as I'm going to Kalamazoo MI to pick up one or two sheets, maybe I should get a sheet or so of 1/4" coosa to make the side panels. I know it's probably not necessary but what the heck. It will make the 330 mile drive worth it.
I am also disappointed that the terminal ends I got from McMaster Carr have a bright silver finish. I would have liked copper like the originals. I guess these will have to do. Still chugging along slowly |
john b
Can anyone tell me the clearance between the spark arrestor and the engine cover on a mustang 302 with a flat top engine cover? I really like the Holman Moody 4V aluminum intake manifold but it looks slightly higher than the original. Although not original, I think it would look nice on the engine. Reluctant to spend the $$ to find it doesn't fit.
Holman Moody 4V intake manifold |
It’ll fit
john b
Thanks for the intake info Tim.
A beautiful day today. Did a little work What should I thicken the epoxy with when I bond the stringers down, hopefully tomorrow? Cabosil? Milled fibers? Microbaloons? I would guess Cabosil based on blue sky. Anyone? I used this Craftsman sabre saw to work on a Glen-L boat when I was about 10yoa. Different day, same hand, but with wrinkles. The arrow of time is unrelenting. Today's work, shaping the secondaries.. I hope all of you here and your family are well. |
John, Both sound good to me. It was a nice day up here too. Warm and sunny so the ice is finally starting to go on the lakes. |
Milled fibers are stronger but cabosil makes for a much smoother, creamy consistency. I’d use a bit of each.
Micro balloons is low strength and better for fairing (when sanding it off will be easier). |
C_Heath
Senior Member Joined: January-21-2020 Location: NC Status: Offline Points: 207 |
good job staying motivated since 2011. I wouldn't be able to at all.
1979 Calipso Runabout (the boat that got it all started)
1988 Mastercraft ProStar 190 (sold) 2000 Pro Air Nautique/GT40 |
john b
Clearly you jest. |
john b
I think I'm ready, but I'd be lying if I told you I wasn't nervous about bonding the stringers down. I am trying to do everything right. I spent some time the last couple days tweaking the stringers to fit the countour of the hull as closely as I could by hand sanding them.
I leveled the hull across the step pad area. It was already very close and a little tire pressure adjustment made it perfect. The stringers are level as compared to the hull. The aluminum angle for the motor mounting is level and 1/8" lower than the original surface. I can't think of anything else I can do to assure a good result. I will clean the bonding areas with acetone tonight and attempt to bond them tomorrow. I am leaving the temp at 70 degrees for the process and using the 3:1 epoxy. The secondaries are shaped to the hull and I plan on trimming them to the correct height, level with the primaries, after the primaries are bonded. If anyone has any helpful comments I would appreciate hearing them. |
Give it just a little bit of pitch on final trimming... will send the water to the bilge.
john b
Thanks Tim. I just can't go back and revisit the fitting of the primaries. In addition to my extremely slow pace i am concerned about mechanical clearance due to cutting everything 1/2" short to make up for the floor. I could pitch it a bit toward the center to drain to bilge by the engine since I haven't finished the elevation of the secondaries yet. Is that reasonable or is the intent to pitch it toward the rear? The front has a lip on the pan so that wouldnt work. A bit of hard acceleration and running just short of the step before putting it away may be my only option. My daughters and grandsons believe if you're not soaked, you're not boating. |
Pitch to the bilge (center).
Morfoot
Late to the game on this one John and Tim was right on the epoxy additives.
Cabosil is basically a resin thickening additive. if you don't want runny resin add cabosil. Microballoons are a Gap Filling additive. Not as strong as milled fibers because they are microscopic glass spheres. Great for adding a fillet seal around whatever your bonding and for rounding out 90 degree transitioning angles. (like stringers to the hull) Fiberglass does not like 90' bends and will lay down a lot nicer if they have a nice smooth curve to follow when going from horizontal to verticle. Off topic but GE uses a mixture of resin and microballons as a rubstrip for an Air/oil seal for the Engine shaft on its motors. They're tough but yet easy to sand. Milled Fibers are added for extra strength as TRB stated but you don't wanna get too crazy and over zealous with them. Too much added and your resin will be weaker because they'll trap air in the compound making the bond weaker A heavy dose of fibers to REALLY thicken up the resin ain't good. Once you start sanding it and it's a mess, it's hard and you'll go through some Sandpaper, you'll see tiny pinhole pockets of air through the harden resin if you look REAL close at the sanded resin. I've seen guys add so much fiber to the resin it looked like crunchy PB on a -20'F day. Bottom line is be smart about it and when you need thicker resin or ready to bond the stringers Think Creamy PB or room temperature Cream Cheese consistency for you Bagel Boys. Keep up the good work John and thanks for the thread! . |
John,
Take note of Tim's comments. He knows his stuff since his skills are what's holding those planes together. Next time you're up in the air on DAL, (if they do ever get back up there!) think of Tim. |
Morfoot
Awwww thanks Pete!
