Not another Mustang restoration thread. |
Post Reply | Page <12345 54> |
Duplicolor self etching primer followed by rattle can crusader blue is shown above. I’ve used duplicolor on everything else and it looks just as good. I’d keep going that route.
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3238 |
Tim, Your engine is really sharp. I don't expect to get show quality results like yours, this thing is a driver. Would you suggest I just finish it with the same Dupli-color I've been using? That would make this thing go much faster and eliminate the color match issue with the powder coater. I also like the look that It's never been cracked open. I have been told to use an etching primer with the steel parts. Do you have a suggestion for the aluminum manifold primer? I can search the net but who knows what advice I'll get.
Thanks for the input on the distributor. I only have this one because it was dumped in my lap with the boat. Nice to know your thoughts as someone who's tuned them. Maybe Mallory is a Ford thing. My first car had a side oiler with a dual point Mallory. That was in 65, I've been told times have changed. Sorry to lean on you so hard. |
john b
All that needs is "FREE CELL SERVICE" on the side to troll. |
All one color Pete and it would make Zach proud- a nice Caterpillar yellow At least it wasn't Bell System green
All the same color or was it one of the psychedelic jobs back in the 60's? |
When I was younger one of my friends would liberate a can of spray paint from work every day via his lunch box to paint his Beetle. Don't remember what kind of paint it was but being in the early 70's could not have been anything great,but I have never since seen a spray can do as nice a job.
As to distributors mine is a clip down with a tach drive. Keeping in mind our boats are something like 27 apart my engine was a 289 serial number 2511. So being the boat is a 69 it's obviously an early HM compared to yours. |
Yes screws usually hold the clips but that’s a clip down in my book. Same Mallory on the HM and Interceptors of the same era if I’m not mistaken. Probably all the Fords. Mine was certainly replaced later. The screws hold down the cap on the prestolite (screw down). No clips.
Maybe I’ve got one with a nice smooth (and fast) curve, but I’ve struggled to get the timing where I want it on a few mallory’s. Messing with the weight and spring kit to get it right is for the birds. I also do not care for the engagement of the clips or how the points plate attaches on the Mallory, everything on the Prestolite just seems beefier and better built. That said I’ve driven plenty of Mallorys that run great so I know it can be done. But working on the Prestolite is easier. |
john b
And there are those who prefer Lovey. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10726 |
John
Only Tim knows the reasons for his preference but as far as your hold downs, the automotive versions of the Mallory YL's typically used clips that resemble those used with the Prestolite clip down cap. The marine units through the years have used a couple of different variations of those aluminum hold downs that you have. Google is your friend if you look for Mallory automotive and marine and Prestolite clip down and screw down cap distributors. Some people like Ginger, some like Mary Ann |
john b
Tim, maybe it's a H/M thing. Both of my H/M Mallory distributors have screw down caps. There are small aluminum pieces attached to the body by screws through the clip mounting holes. The cap screws thread into them. They are Mallory L445 distributors with the tag YL445KV. They may have been special orders for H/M. They are listed as Dearborn LH 8 cylinder with Mallory cap 18-5375. I ordered a repro from Sierra and it is designed as a clip down, but this mounting hardware makes it a screw down. |
Rattle can job above, an automotive spray job would be nicer but you can get decent results without working too hard. I’ve used stainless hardware quite a bit on my engines but I prefer the original monochromatic look on the older stuff like above... I just spray it all.
I’ve never been all that impressed with the mallorys, theyre all clip down that I’ve seen. Prestolite made clip and screw down versions, typical of 80’s era pcm’s to have them. The latter is on my conqueror crusader, it’s a nice, simple piece. The mallorys can be made to work fine too though. I |
john b
I wish my engine would look as good as yours,it's beautiful. I rattle caned mine and it tunred out fairly wel. I don't have to worry about the finish on the vlve covers because I'm using the original stamped chrome ones. There won't be much of the engine block and heads to see and I think that manifold will look very nice. I have talked to a powder coater and I plan on having him coat the manifolds, brackets, mounting hardware, and assessories. I have two original iron 4V manifolds with the proper casting #. I have no line on the H/M intake. I would buy it new at retail off of their website.
I am confused about the comment about the screw down distributor cap. Aren't all the Mallory crab caps screw down? My Mallory is a dual point that has had the second set of points removed and the condensor installed internally in their place. I rebuilt it and installed electronic ignition. I have to points plate to drop in if it should fail, but I have used this brand in several boats and have never had a problem. Funny that the distributor had the original Mallory tag on it. H/M basically dipped their engines in blue paint Everything was covered and it is far from the quality on your engine. The original Mallory tag was on there but had a thick coating of paint. I managed to remove the paint without damaging the tag, but I covered that back on the pages around 35-40. I am considering replacing all of the fasteners on the engine with SS. I like the look of the originals, but with the parts powder coated it may look funky. Has anyone else done this? Don't get your blood pressure up Pete. Off to work with epoxy again. |
Looking good.
If you have a line on that intake for short money then grab it. I’d pass on the DUI for that set up, though I love them in my chevies. No reason you can’t have reliability with the old Mallory stuff... though I do have a preference for the Prestolite (especially the screw down cap style), it just seems better put together. Either looks good on a vintage Ford. |
NCH20SKIER
Well done John
'88 BFN |
John, I'm with you on that. In fact, I typically look for something I can grab onto before getting down at floor level. It's looking great. |
john b
I think I have it figured out. Smaller batches, right consistency, finish like a caulk joint. I used the tongue depressors I got from U S Composites. Trying hard not to accidentally get the epoxy on a finished surface. It's hard for a geezer with bad knees to get up and move constantly without grabbing something I shouldn't. I'll need to order some more stuff before this thing's done. Steep learning curve here.
I am so tempted to buy the H/M aluminum intake and a DUI distributor and put the original stuff in a box. I know there are some that won't agree, but reliability is paramount and a little jewelry thrown in wouldn't hurt. Thanks for the tips! |
john b
Does thickening the epoxy with Cabosil and a few milled fibers to a thickness of peanut butter or cookie dough cause the epoxy to go off faster? I had a little over one hour pot life with the mixture I used to bond the stringers, but it was too thin. I mixed up a batch to do the fillet joint and it went off in about 12-15 minutes. The temp last time was 75 and I reduced it to 65 for this batch since I thought it would take more time to get the joints neat. I'll mix smaller batches in the future to avoid this problem.
The good part is the joint turned out really nice and smooth where I was able to finish it. |
Any roughness in the fillet can be avoided by putting down a layer of 2” tape right over it and wetting it out before it cures.
It definitely sounds like you mixed it too thin. I find a little over 1:1 on volume is a good starting point (cab to mixed resin). Then add until the mixture sticks to the cup when you turn it upside down. Just don’t go too far and let it get clumpy. |
Morfoot
I'd go ahead and mix up some resin and Microballons to make your creamy peanut butter and lay down your transitioning fillet seal so the glass will lay down nicely. A Tongue depressor works great if you've got some. Also for a REALLY smooth finish then you can drag a rubber gloved index finger dipped in alcohol or acetone for that silky smooth surface. I say either one as one works well with some resins and the other one doesn't. Same thing applies to silicon rubber. Spit usually works best but sometimes it's rubbing alcohol that works the magic . You can also cheat the system by smoothing out either by using a bottle sprayer to mist it first. Then smooth it out. Tricks of the Trade! LookIn' gooooood John. |
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1184 |
Nice job. Keep going
Looking good John
john b
Since I'm almost finished with the original stringers I left them outside in the rain last night. The fiberglass had become disbonded from them and they were floating free in a fiberglass shell. They were in boarderline condition but I question how long it would be before any new fiberglass applied to them would disbond. They have absorbed a lot of bilge oil over the years, enough so that the water beaded up on them, as I suspect the epoxy would do as well.
John,
One thing I have found when using epoxy and that's when it starts to heat up, the vicosity goes down. Regarding the next coat, the sooner the better. Before a full cure, you get a chemical bond on the next layer rather than just a mechanical bond. |
john b
I turned the lights out in the garage at 0230 today. I listened to all the advice and it turned out ok. I thought the epoxy was thick enough, but I wasn't able to make a filet joint with it. Thicker next time. Sheesh, it takes a lot of Cabosil to thicken this stuff. I searched for some info on US Composites site about how long to wait and what prep I need to do to put on the next layer that make that filet joint. Didn't find it yet. any suggestions?
I don't like the look of the rudder port backing, especially the little piece of plywood used as a spacer. I plan on making it out of laminated Coosa. Should be stronger and look neater, but the original was apparently strong enough. I may start wiring the panel soon while waiting between epoxy applications. I plan on zip tying the harness to the front lifting strap under the deck with the plug from the instrument harness to the main harness about 6" under the deck. Seems like that would work ok. Here is how it stands this morning. |
Morfoot
Awwww thanks Pete!
John,
Take note of Tim's comments. He knows his stuff since his skills are what's holding those planes together. Next time you're up in the air on DAL, (if they do ever get back up there!) think of Tim. |
Morfoot
Late to the game on this one John and Tim was right on the epoxy additives.
Cabosil is basically a resin thickening additive. if you don't want runny resin add cabosil. Microballoons are a Gap Filling additive. Not as strong as milled fibers because they are microscopic glass spheres. Great for adding a fillet seal around whatever your bonding and for rounding out 90 degree transitioning angles. (like stringers to the hull) Fiberglass does not like 90' bends and will lay down a lot nicer if they have a nice smooth curve to follow when going from horizontal to verticle. Off topic but GE uses a mixture of resin and microballons as a rubstrip for an Air/oil seal for the Engine shaft on its motors. They're tough but yet easy to sand. Milled Fibers are added for extra strength as TRB stated but you don't wanna get too crazy and over zealous with them. Too much added and your resin will be weaker because they'll trap air in the compound making the bond weaker A heavy dose of fibers to REALLY thicken up the resin ain't good. Once you start sanding it and it's a mess, it's hard and you'll go through some Sandpaper, you'll see tiny pinhole pockets of air through the harden resin if you look REAL close at the sanded resin. I've seen guys add so much fiber to the resin it looked like crunchy PB on a -20'F day. Bottom line is be smart about it and when you need thicker resin or ready to bond the stringers Think Creamy PB or room temperature Cream Cheese consistency for you Bagel Boys. Keep up the good work John and thanks for the thread! . |
Pitch to the bilge (center).
john b
Thanks Tim. I just can't go back and revisit the fitting of the primaries. In addition to my extremely slow pace i am concerned about mechanical clearance due to cutting everything 1/2" short to make up for the floor. I could pitch it a bit toward the center to drain to bilge by the engine since I haven't finished the elevation of the secondaries yet. Is that reasonable or is the intent to pitch it toward the rear? The front has a lip on the pan so that wouldnt work. A bit of hard acceleration and running just short of the step before putting it away may be my only option. My daughters and grandsons believe if you're not soaked, you're not boating. |
