  New Posts New Posts RSS Feed - Nautique 200 - 409 engine, transmission slipping
Albertocsoares View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertocsoares Quote  Post ReplyReply Direct Link To This Post Topic: Nautique 200 - 409 engine, transmission slipping
    Posted: January-29-2012 at 2:20pm
Hi everybody!
2010 Nautique 200 CB, 409hp, 380hrs.
Yesterday after pulling a first set of slalom, I engaged forward and nothing happened. I noticed the cable was not engaging the transmission all the way, I tied the cable and the boat engaged forward but I felt the transmition began to slip when accelerating the boat.
I changed the oil, it looked fine, no water or other debris. I changed the position of the cable support in order to get a complete transmission engaging, with no gap at all.
I tried it on the water, it was fine, but after the transmission heated up it began to slip again.
Any ideas?
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: January-29-2012 at 2:57pm
Alberto - Is your oil cooler working OK? Maybe it is clogged.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-29-2012 at 3:19pm
you probably glazed the clutch plates from the mis-adjustment and they lost their ability to hold under power. PCM trans?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertocsoares Quote  Post ReplyReply Direct Link To This Post Posted: January-29-2012 at 3:46pm
Thank you SNobsessed! I will check the oil cooler, in fact I noticed the transmission was really hot.
Yes Eric, it is a PCM trans. In case I damaged the clutch plates do you think the trans would heat more than usual?
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: January-29-2012 at 4:52pm
Does Nautique still carry a warranty? What happened to the 5 years "Stern to Stem"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-29-2012 at 6:04pm
Ryan,
This is a nice idea but if the problem is in fact caused by plugged cooling that the user is in control of, then I'd be inclined to think it would not be covered.
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2012 at 1:06am
Ryan,
Although, if it was caused by the misadjustment, that's not necessarily user error, I'd think that would put it back in the hands of the company.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2012 at 11:14am
your facing a kunnundrum, you are subject to dealer pricing if they deny the warranty, i would imagine the list price on the trans is up there....make a few calls and see if its covered under warranty.....let them figure out the details, drop it off and say its broke, just say its slipping and you dont know why
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2012 at 12:20pm
Clean out your raw water strainer, and water intake side of your tranny cooler, then drop it off and say it's broke and you don't know why.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2012 at 12:47pm
I don´t know how it works in brazil, but down here there´s no dealer at all, just a middle man who takes orders, and place them to the factory...then they work with certified shops such as the one where lucho works...
In the event of a failure, they will have the shop to take a look, and if in case the problem is under warranty, the "dealer" will make the claim to the factory. Mechanical problems, they can send the part and have it replaced. But hull problem warranty is hard to have it repaired under warranty!!
Lucho can explain better than me how it actually works.
So in other words the user its at its own...
<a href="">1992 ski nautique
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2012 at 9:08pm
Alberto, I service the Nautique boats for the local dealer in Argentina, go to whoever sold you the boat and tell them whats happening. When a boat like this is under warranty you dont touch anything yourself, in fact, new boat owners are a pain in the a,,,ss because of this. If you want to get warranty covered you are tied to their service dept until warranty is gone.
The dealer should have a qualified mechanic approved by factory to diagnose and work on your boat. They should step in and professionally repair or replace the damaged part. If they figure out you messed with the cable adjustment on the damaged part, they can try to void warranty and claim it was your responsability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertocsoares Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2012 at 9:07am
Thank you all for your kind help, unhapply we do not have Nautique service here in Brazil, next Sunday I will check if there is any obstruction in the oil filter and pray that this will solve the problem, I will come back to you after that. Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2012 at 10:09am
search for nautique dealers
There seems to be some in Brazil, maybe not in your area. Talk to them first as they can work as a faster link between you and the factory warranty dept.
I repeat, if you want to get any kind of warranty out of what your expensive new toy, DONT do anything yourself unless warranty dept tells you to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2012 at 10:15am
Alberto,
Hopefully the overheat slip didn't do permanant damage warping the plates and Eric is correctthat they are simply glazed. In ether case, you may end up having to tear into that trans.
No marina down there that's certified to work on a PCM trans?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertocsoares Quote  Post ReplyReply Direct Link To This Post Posted: February-01-2012 at 7:26pm
I only found ZF and Velvet trans services in Brazil, do you know if the PCM trans I have is one of these? It only reads PCM, but also reads made in Italy, I know also it takes 1.9lts of ATF oil. I will only be able to post pictures next monday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: February-01-2012 at 7:36pm
Look for the closer Nautique dealer or call factory, ask them how they want to proceed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertocsoares Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 5:29pm
Good news, I contacted PCM´s warranty department, they will send me a new transmission ASAP. I am glad I bought a Nautique, their partner PCM really knows how to treat their clients.
Thanks everybody!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 8:24pm
told you... glad you got it rolling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-11-2012 at 12:13am
Alberto - Glad to hear that they are taking care of it.
If you find out what failed in your tranny, let us know.
We always like to hear the rest of the story.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertocsoares Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2012 at 8:08pm
Hi guys!
Just changed my damaged transmission for the new one PCM sent me. It was pretty easy, about 3 hours (2 men) job. I changed also the oil cooler, just in case...
I still think the new trans is working at a high temperature, but after some internet research found out that it is supposed to work around 150-175F. Is that correct? The maximum I can keep my hand on its top is about 10 seconds.
Next week I will open the old trans and post some pictures in order to find out what happened, probably it is not very damaged, as I stopped the boat as soon as it began to slip.
Thank you all, specially Jody Seal who indicated the PCM warranty contact!
Alberto
