  New Posts New Posts RSS Feed - ATF or SAE 20W
ATF or SAE 20W
gugi55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gugi55 Quote  Post ReplyReply Direct Link To This Post Topic: ATF or SAE 20W
    Posted: February-07-2012 at 1:07am
I am restoring a 74 skier 16' with a 302 Ford. I am changing all the fluids and am trying to decide if I should go with ATF or 20W in the tranny. The 20 W will give it quieter operation and has better lubricating qualities but the ATF is what is recommended(we use 20W in outboard lower units). The ATF is not operating as a power transfer fluid and does not have the same lubricating qualities.
WHY ATF in the first palce .... and comments or words of wisdom!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2012 at 8:01am
The ATF is basicaly a 20 weight and is easier to find. There's nothing wrong with using it and would be my first choice. All it's doing is providing hydraulic pressure to the clutch packs. Yes, it does lubricate as well but mostly in reverse when you are spinning the planetary gear set.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2012 at 9:55am
and atf is reccommended because it wont foam over 3000 rpms, no problem using motor oil in them in diesel applications
atf has anti-foaming agents added
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2012 at 10:14am
Comparing a marine trans to a O/B or I/O lower unit is really a pour comparison. Totally diferent gearing plus, the HP going though the lower unit gears which are always on the small side is very demanding. A lower unit is a gear engineers nightmare!
