  New Posts New Posts RSS Feed - bottom paint
bottom paint
MAN - GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MAN - GA Quote  Post ReplyReply Direct Link To This Post Topic: bottom paint
    Posted: February-07-2012 at 2:07pm
when I purchased my boat the PO had installed bottom paint from the water line down. He had the boat in the water for his summer vacation as a grocery getter alongside his houseboat. I am thinking about removing the bottom paint and then wetsanding back the gel coat. Is this just going to be a labor intensive job or is there alot more to consider for the process? (other than safety working with the copper in the paint)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2012 at 2:58pm
Mark,
It can be done but I suggest using a paint stripper that states it's safe on fiberglass. Some bottom paints are harder to remove than others. I had made the mistake of using an ablative on the bottom of my X55 (wood hull) and wanted to go back to the traditional bronze. That ablative was a "bear" to get off even using methylene chloride (Zip Strip)
aDrifter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aDrifter Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2012 at 2:31am
we use Aqua strip at the boat yard i work at. It seems to work well and isnt crazy toxic. It doesnt affect the gel coat at all either.
must_dash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2012 at 6:16am
I have the same problem, po used antifouling. I had considered a sand and polish, but as the boat lives in the water I am going to scrape the old paint and repaint.
A lot will depend on how he sanded the hull before painting it. Maybe do a test area to see the condition of the gel before committing and finding he used a coarse sandpaper.
Tom
1986 Martinique - sold
When we ask for advice, we are usually looking for an accomplice.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2012 at 12:46pm
Sometimes a bottom paint is used to hide other evils. Other times you might find a nice 'oak floor' underneath.
1988 BFN-sold
