  New Posts New Posts RSS Feed - water in bilge 85 ski nautique
loosemopar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loosemopar Quote  Post ReplyReply Direct Link To This Post Topic: water in bilge 85 ski nautique
    Posted: April-17-2012 at 2:14pm
I have an 85 ski nautique purchased late last year. At that time i noticed excessive water in bilge. this week i changed the packing for both the rudder and propshaft. while out adjusting I was still getting water found it to be coming from behind the gas tank from the speedo tubes. before i pull the gas tank what should i be looking for??
thanks for your help
Lou
dwcar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcar Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2012 at 2:26pm
Could be coming from where the rubber tube goes thru the hull to the speedo pickup. It might be that one of your exhaust hoses has a hole in it or is not clamped properly. you should be able to see it with a flash light with the tank in.
83Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2012 at 2:28pm
It could be coming from a couple different places.
1)the lag bolts holding the platform brackets (pointing at in pic)
2)around the exhaust tips
or
3)the pick-up tubes (under arm in pic)
Post Options Post Options   Thanks (0) Thanks(0)   Quote loosemopar Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2012 at 3:37pm
it is dripping right off the tubes so I dont think it is the exhaust
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2012 at 4:31pm
Check the tubes(brass thingys) for cracks I had one that must have frozen and cracked when the PO didn't blow them out during winterization.
Also check the tubing(plastic) for cracks and that the connections are tight. You may have to cut a little off the plastic tubing to get it to seal tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote loosemopar Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2012 at 10:00am
Thanks guys I guess the tank will be coming out
