  New Posts New Posts RSS Feed - 99 SN GT40 Fuel Supply
 Post Reply Post Reply Page   123 5>
the good ag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote the good ag Quote  Post ReplyReply Direct Link To This Post Topic: 99 SN GT40 Fuel Supply
    Posted: August-26-2014 at 8:56am
Replaced the hi pressure pump,   no wonderful little hum of the hi pressure pump.   Read some more around here and thought what the hell let's play with the man overboard kill switch.   Bingo
All is good with the kill switch bypassed.
Sidenote - threw away volt meter that showed power to hi pressure pump, when it obviously was not getting power due to the kill switch.
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2014 at 9:40pm
If the low pressure pump runs but the high pressure does not with EEC STO jumpered.
1. Check connections and verify voltage at high pressure pump connector.
2. If that all checks out replace high pressure pump.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote the good ag Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2014 at 7:13pm
OK all, this has been very informative and helpful but I've got a variance of the problem going on right now.
I do not get the hi pressure pump buzz, to make it even more interesting after working on it last week I got back to it today. Did nothing but said to myself "let's give this a try" , there it was the hi pressure pump buzz we all know and love, did it 3 times and all is good, put the water on the engine and started the engine right up.   Then about 4 minutes later motor dies and I can not get the high pressure pump to go any more.
I have tried putting new relays, I tried the jumper suggested above, no go.   Circuit breakers look good, kill switch is in place.   I'm positive this is something easy if I can just find it.
Look forward to hearing your ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2012 at 11:57pm
While not related my Dads Lincoln electronic dash went out completely,he went to the dealer they said sorry no parts available to fix it,they would just replace the whole unit if they could get it. I did a web search and found a place that would fix it for 275. I pulled it out sent it in and it took them a week and has a year warrenty. Maybe there is someone who is out there to fix them but don't expect a dealer to find them,you'll have to do the leg work.
Doing a quick search here is a place that says that they will repair and return your ecm if they don't have one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2012 at 11:27pm
Al was hoping all the way along it was not the ECM. You basically have to prove everything else is OK before replacing. I doubt your dealer would have been as logical in fault finding before deciding to just swap out ECM.
Just think what the dealer would have charged you to fix the problem.
There must be a business in the US that repairs auto ECMs. As the GT40 is a Ford auto based solution they use the same ECM (EEC1V) but with a slightly different "program" stored in the PROM (Programable Read Only Memory). If you can find this company send your old computer there for repair. Make sure that they send your original one back.
89 Ski
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2012 at 10:37pm
Started up the boat in the driveway with the new "used" ECM and it ran fine. No fluctuations in fuel pressure, gasping, or stalling out.
Its a bummer that there is no test to see what is wrong on the ECM. I think maybe someone who fixes televisions or radios, etc., might be able to determine what is wrong with the board and repair it.
Should get the new ECM 300 model later in the week. I will plug that in and take it to the lake for the real test!
Thanks for all the advise and ideas on this, it definetley helped me get to the core problem.
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2012 at 11:35pm
Well, the ECM came in direct from PCM. It was a freaking old ECM off of some other engine, not even the 300 model that I ordered from a dealer. They sent me a 290. The case on it looked like it was dragged around on the floor vs. mine that looks basically new, so no telling how many hours were on it.
A call to the dealer and he straightened it out with PCM and I am getting a new 300 sent my way.
PCM says that Ford stopped making them so they are getting very hard to get.
My question is: Is there a repair shop that could go through all the resistors etc., on the board and determine what is wrong with it, and repair it? This thing might be worth its weight in gold some day!!
I am going to pop the new "old" ECM on tomorrow hopefully, and see if it at least runs well in the driveway.
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2012 at 12:44am
Lewy,
The unidentified wire I posted about comes off the 60 amp fuse. There is also a single brown or green wire that is not connected to anything. Hard to tell if it is a dead end wrap from the factory or if it goes somewhere, because the endof the wire is encased in a black fitting,mbut there is a hole at the end, like something could be plugged into it.
I have no idea what those wires are from schematics.
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2012 at 11:15pm
Well, the PCM Tech said that there was no test for the ECM, and you can only rule out everything else. I believe we have pretty much accomplished that.
I will order an ECM tomorrow and post results after it is installed.
I appreciate everyone's help out here. I have learned a lot more about the GT40. It has been a great running engine for 12 years, aside from a pump relay issue a couple seasons ago, I have put oil in it, new plugs, and the occasional impellor. So if I need to drop some bucks this year, I guess it will average out to be a pretty low cost over the long haul..
Weather is starting to warm up, so hope this is the fix!!
AB
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2012 at 10:52pm
Al with the engine running tests (KOER) it raises the rpms up and down a few times. I have a video or the KOER for future reference if you require.
Before going any further I would replace the ECM. I think your house is safe.
It would be nice to borrow one for a test. Once again wish I was closer could swap over ECM's and confirm it is the cause without spending $$$$$.
It sounds like you have a internal grounding problem in the ECM itself. The earth to start pumps and then the earth to code reader are the missing connections in ECM.
89 Ski
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2012 at 6:56pm
Ok, pulled out in the driveway and started it up. Ran freaking like new. No hissing, pumps primed, etc., let it warm up and then took it up to 1500rpm and then razzed it and not a missed beat.
Tried to hookup the code reader to get some KOER readings and although little tringle showed, it wasn't reading, so while engine was running at idle, I disconnected the single grey test lead and grounded it (BECAUSE IT WASN'T READING WITH IT CONNECTED TO READER). Oh boy, the engine jumped up several hundred rpms, started hissing immediately, and died... Looked like code 08 was being displayed, so it was reading a V8. I tried to recall from memory and nothing came back..
I tried to get some KOEO readings, and again, no readings with the single wire plugged into the reader, so I grounded it, and when I did, the pumps primed. Read 11 and 10, so zip and zip. When I unplugged the ground, the pumps primed again.
What the heck? Can the single test lead be tied into shutting the pumps and other stuff off? Or is this all another coincidence to throw me off track for the 20th time??? I THINK THE CODE READER TRIGGERS THE PUMPS WHEN ENGAGED, CORRECT?
Going off to study diagrams...
Went back out to see how it would run again. Started up ok, pumps primed, and idled for a while, took it up to 1500 and then hissing started, then shortly thereafter, missing, loping, and stalled. I could not make it run long enough to get any codes while running. I hooked up KOEO, and again, 11, 10, 11. All clear..
I tapped on the back of the ECM with key on, and PUMPS PRIME everytime, it is comical..
I am betting the house on a bad ECM and will order one on Monday from the lowest bidder!
I don't know if heat plays a role, as it runs ok for a little when it is cold, then then crappy. I can't explain why it ran well in one of the videos I posted a while back, or why it REALLY ran well today when I started it up. Took rpms great, took throttle bursts without any skipping, like were present in the video, and then just crapped out and ran bad the rest of the time. Could not get it to run like the initial 5 minutes.. The last time I had run it a few days ago before I took the ECM off, it ran like crud, so why it started up like a beast today??
Any last minute thoughts??
Oh, the code reader doesn't really work unless I have it grounded on the battery. For whatever reason, the single wire has to be off and grounding to the block or motor frame doesn't cause the square box to pop up, only ground direct to battery. I am not sure this is significant or not, but would throw it out there..
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 11:52am
Al,
This video should help you with Code reader
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 1:36am
The larger triangular connector is the STO connect it to Code reader. If the code reader will not communicate with ECM with single STI wire connected to code reader(no link indicator on code reader) disconnect that single STI connector and ground with jumper as the code reader manual indicates. (Page 75)
89 Ski
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 1:21am
Originally posted by lewy2001 lewy2001 wrote:
Al it looks good no signs of water intrusion or oxidation. The earth tracks and power tracks on the board look OK from the pins out. The whole board is coated to aid in water resistance.
Put it all back together and see if you can the pumps to prime and the engine to start. It may take some tapping of the ECM or jiggling of ECM connector. After you get it to this stage turn off engine. Connect Code reader and see if you can get the code reader to run the KOEO tests and retrieve any stored Continuous codes. It may require the grounding of single STI wire we mentioned previously.
Just to be sure, when I hook up the code reader, I plug in the triangular plug to the STO AND the single wire on the single plug, or just the STO? I jumpered the single wire earlier tonight, and it seemed to read, but I don't know if it was because I had no power through ECM.
I just put the ECM back on and plugged everything in, and the darn pumps PRIMED! My wife has a card party at our house tomorrow night, so probably won't be able to run it until Friday or weekend.
***EDIT***
I do not see any bulging in caps but it is hard to tell from a picture sometimes. Sometimes the plastic coating goes on thicker around components giving them a rounder appearance. The ECM may be the fault but let's try and get some fault codes out of it.
Yes I noticed some buildup, but it looked more like excess coating, sort of a paint run, than bumped up from damage..
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 12:47am
They are flat.
harriss28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harriss28 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 12:43am
the caps are the tall, can-like component. the tops should be flat, not bulged. capacitors fail quite often.
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 12:41am
Originally posted by Bri892001 Bri892001 wrote:
Are we absolutely sure the pumps are supposed to prime every time?
You definitely checked all the cheap stuff? Tank screen? Antisiphon valve?
You know you're getting consistent flow from the low pressure pump out of the tank when you're jumping it?
I know the distributor has come up before. Not totally sure how you'd test that. I know sometimes I distributor equipped car that won't take revs can have a bad distributor.
Drained and blew out the tank, changed anti siphon valve, pumps run fine jumpered, but engine still stalls and acts like ignition problem, see pressure on rail and no fire at all. Changed cap and rotor and plugs this spring.
Pumps should prime every time, full pressure or not for 2-3 seconds. Mine are sporadic. They run when STO is jumpered, and with key on engine off with no prime, I tapped on ECM cover and they primed. Several times. Shaking wire harness etc., had no effect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 12:35am
***EDIT***
89 Ski
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 12:31am
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 12:28am
Which ones, the tall brown cylinders?
I really don't see anything, flat or cylindrical that is bulged out, loose, or burnt.
There are some connections at the neck where the 60 Pin plugs in and I can't see if there are any irregularities there. M
If tapping on the ECM cover made the pumps prime, I would have thought something n the board would be loose, or solder not good.   Don't see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote harriss28 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 12:20am
i see there are 2 capicators. the tops should be flat. if they are bulged, thet need replaced. its an easy inspection nad easy fix
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2012 at 12:12am
I don't really know what it is supposed to look like, but I didn't find any loose connections, burn marks, or water marking.
It would be great if you could connect a meter on two pins and know if it is good or bad!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 11:56pm
You just did if you have power at those pins 37,57 and ground on 40,60 then the ECM is getting its power and earth. Take ECM out of housing and inspect as I mentioned previously.
89 Ski
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 11:11pm
My bad, sorry.
I was on 17 pin. Forgot it was upside down. I got excited there for a minute! Middle row doesn't change!
Have my iPad in boat. I have power at 57 and 37.
Is there a specific section in manual I should follow to check ECM power and ground?
I talked to PCM Tech on phone today and he said there are no ECM tests to see if it is bad. Just eliminate everything else and read codes.
I can't get codes!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 10:41pm
Al,
Yes according to the diagrams pin 57 should have power just like pin 37 and also have continuity back to "87" on EEC relay. It does show a join in the wiring diagram. The join could be anywhere in wiring loom though. Chase the wire back from the pin on connector and see if there is a join before it goes back into the main loom.
***Note*** always remove power when testing continuity.
And you are right earth is earth because the the main heavy earth wire runs from battery -ve terminal right to the cast iron block of engine.
Trying to get codes from the computer will not be possible if the computer has not got power and earth. You may need to catch it when the pumps are priming. You are very close I hope it turns out not to be the ECM.
89 Ski
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 10:19pm
Lewy,
I have power at 37 and it has continuity to relay 87.
57 has no power and no continuity to 87.
60,40, 20 are grounded with continuity check ok.
Shouldn't 57 have continuity with 87?
I checked power with key on.
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 12:31pm
Lewy, I didn't communicate properly. When I turned the key on to get codes, the pumps didn't prime. So, that was telling me that my system was in trouble mode, so I thought that I would NOT get any codes if power wasn't flowing through the system.
I jumpered the single wire with the STO jumper wire I had rigged up. I grounded it on the block like the STO, not to the negative terminal on the battery like the manual shows. I figured earth is earth.
I will pull apart the 60 Pin and test tonight, then take the ECM apart and see what is in there...
Thanks for all the help.. I have learned a lot, even at times if I have frustrated you and the other guys out here trying to help, I appreciate it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 12:17pm
Al I think you have got the wrong idea here. The code reader will not start the pumps. It is only when you ground the blue/orange (fuel pump relay ground) wire on the STO that the pumps will start. Remember it supplies the ground to start the pumps that the computer normally does. From memory they do start as part of the KOEO test but they do not run continuously like when you jumper the STO connector to earth.
Al Page 75 of the Code reader manual has a code reader trouble shooting guide. I think Gordon had to ground the single wire (white/purple STI) to get his code reader to communicate with ECM. As described on page 75 of manual.
It may just be that your ECM is bad.
You checked all the grounds on engine previously right?
Also you metered pins 40 and 60 to ground at 0 ohms previously. So that confirms the computer was getting a good earth.
Pins 57 and 37 are power to the computer you should have 12V on those pins. NOTE "With key on"
Take the 60 pin ECA connector off again and just measure the voltage (12V) at 57,37 and check for ohms from earth to pins 40 and 60 again.
I am thinking they will meter fine and the problem may have been a bad ECM circuit board all the time. I was hoping this was not going to be the case but it is not looking good right now. This helps explain the intermittent nature of the fault earlier that was looking like a bad connection somewhere. The bad connection is inside the ECM.
Not sure if you have removed the computer circuit from the housing and inspected. But I would do that and check for possible signs of water intrusion or corrosion. I would look for a broken track on the ECM also especially around the bottom where the cct board tracks go out to the connector pins.
89 Ski
AMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 1:27am
Well, I took a break tonight and went skiing, behind another SN.
Came home and unboxed the code reader, put the batteris in, and hooked it up to the STO. Turned the ignition on, then turned the code reader on, then hit the test/hold button, as per directions, and zippo. Meter did not show the little triangle in right corner which means that it is accessing the computer codes. Tried this several times, and re-read directions.
Should the engine have some stored codes at least, even if I hadn't run it in a day or two?
Maybe I am just jinxed with electrical stuff!
ps. reading some of the trouble shooting info on the code reader, it indicates that if there is a bad ground, you may have to ground the single plug that is back there with the STO. Hmm, could I have a bad ground and therefore no readings from the ECM?
Ok, this is starting to get me pissed off. I went back out to the boat and when I turned the key on, the pumps didn't prime, I don't know why I wasn't listening for this before. I jumped the single switch direct to a ground like the code reader guide says, and still nothing.
I jiggled all the wires to see if the pumps would prime, and then tapped on the back of the ECM. Bingo! Pumps primed. Tapped again, pumps primed. Did this a few more times.. pumps primed.
No code readings, just stuck on 000. So, my conclusion is that the ECM is not making a good ground, or has some faulty connections internally, and I am not going to get code readings from it, just as my engine is not getting proper signals.. Thoughts?
I don't think I will be buying a $1000 fuse block for more testing, but that might be the only way to get to the true answer, as that is how you test the ECM, right?
Still going through hell, but seeing some light..
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2012 at 12:22pm
Sorry Al have been a bit swamped the last few days and will be tomorrow as well. Get the Code reader and see what codes have been stored. The book that comes with the tester is very easy to read and understand. There are three types of faults KOEO(Key On Engine Off) KOER (Key On Engine Running) and continuous codes. The book tells you how to run tests and explains the codes better than the GT40 manual.
The PIP is a hall effect device it is possible to test but if the fault codes point to it just replace.
I had a look and that green wire goes from that connector and re enters the loom up near the fuel rail. It comes out of the same split tubing in the bilge where the main power loom goes back to the dash. Have not have a chance to see where it appears behind the dash yet.
89 Ski
