Repair /solder Tank sender Tag on 89 SN2001 |
tjamesbo
Senior Member Joined: July-13-2008 Location: United Kingdom Status: Offline Points: 110 |
Posted: May-06-2012 at 8:21am |
Tank is out but when disconnecting the sender wires the tag that isn't on the centre nut came away at the soldered join to the tank
looking at the picture I think the remaining bit left see piccie is steel not ally so I am hoping I can solder a new wire / tag on to it Any Tips on how do do this successfully ? No 1 yes the tank is empty and i intend to fill it with water for the soldering |
lewy2001
Use a round terminal on the wire and put that under one of the five small bolts holding the fuel sender in place. Just make sure the surfaces are clean providing a good earth point.
I agree with Mark on using one of the mounting machine screws as a ground.
Have you ever tried soldering aluminum? |
tjamesbo
Sometimes you cant see the wood for the trees!
if I'd thought more I'd have realised thats the earthing connection Thanks |
