  New Posts New Posts RSS Feed - High oil pressure reading
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Topic: High oil pressure reading
    Posted: June-07-2012 at 12:17am
For the past few years I have been seeing a slow rise in oil pressure readings. Last year it read 80 most of the summer. This spring it is pegged to the right. oil is clear, and just below full on the dipstick. My searches state a bad ground would give a low reading. What gives a high reading?
1987 Ski Nautique
Big t View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big t Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2012 at 12:45am
If the resistance gose up the gauge normally will read higher are the contacts clean?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2012 at 9:37am
WRONG! As resistance goes DOWN, your gauge goes UP. This is why the suggested test for the gauge is to remove the sender wire off the sender and ground it. This removes the resistance of the sender and the gauge should peg at max if it's good.
Dave, Get a mechanical pressure gauge T'd in at the sender to check out what you are actually getting.
