  New Posts New Posts RSS Feed - removing paint from gelcoat
markb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markb Quote  Post ReplyReply Direct Link To This Post Topic: removing paint from gelcoat
    Posted: November-07-2005 at 2:42pm
Hi,
Been spamming you guys lately but I have too many questions :-)
On close inspection of my '76 it appears that at one stage of it's life it had been painted white over the gelcoat.
It's got a bunch of spider cracks etc so in the near future it's looking at a repaint or something of that nature.
My first idea is to see if I can remove the top layer of paint and restore/repair the gelcoat.
If it's too far gone it's 2 pack polyurethane over the whole lot and new decals.
Anyone got any idea if the layer of paint(it's pretty badly oxidised and thin) could be easily removed. I am a**uming it will need to be sanded back but stripping it and uncovering the gelcoat would be my preferred option.
Any ideas on this one appreciated.
fishyflorida View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fishyflorida Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2005 at 7:53am
If you try sanding it off, you will most likely accidentally damage the gelcoat underneath. (Coarse enough sandpaper to remove the paint without loading up will deeply scratch the gelcoat). On the chance that the gelcoat can be salvaged, try a stripper that is safe for fibergla**, such as "Peel-Away". It's not fun, but with only a thin layer of paint it should come off quickly.
82tique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 82tique Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2005 at 8:45am
two words....oven cleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote markb Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2005 at 8:15pm
This is known to soften gel coat not that this is a drama as it will be primed and polyurethaned afterwards as I assume it was painted for a reason.
I was thinking citristrip as well but it may well be an oven cleaner fest.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2005 at 11:26am
you don't have to use coarse sand paper to remove the paint, 1000 grit and a DA will get the job done in no time. Took me all of ten minutes to remove the stern lettering this way. Now if you are doing this by hand then that's another story.
