1983 Ski nautique update |
Post Reply | Page <12 |
markb
Groupie Joined: December-24-2004 Location: Australia Status: Offline Points: 76 |
If you have a quick look through the refernce section you will find that 1979 matches your boat. split windshield, matching rear vent, flat at stern with no vee bottom. I wonder if it possible that it was first registered in 1983? Not sure what your licencing and registration rules are in the USA. The HIN will tell you for sure though or at least it should but either way it's the pre 1982 2001 hull no matter what it tells you. |
Andrew McBride
Groupie Joined: May-30-2005 Location: United States Status: Offline Points: 44 |
I dunno, I am all confused on the year now.
When I get back home I am going to re-check the Serial but I remember seeing the 83. I am going to call correct craft and find out if they have any info. on file and maybe I can get it figured out. It doesn't really matter that much on the year, but it is odd. |
Andrew McBride
83' Ski Nautique "Under Construction" |
markb
My best guess is it is a 1979 rather than '83. It's definately not a 2001 though. |
jameski
Here's an interesting related thread:
Difference between ’81 and ’82+ Ski Nauti The 1981 boat billgatesceo was looking at had the tapered chines, but not the vee-hull ...just like yours. |
jameski
When I bought my boat, the t*tle said it was a '76, but it was actually a '78 - according to the Hull ID number. The hull ID is very easy to interpret - the last two numbers are the year. What is your Hull ID number (its the number stamped in the gelcoat on the top starboard-side of your transom - just below the rub rail)?
Is it possible that Correct Craft made a non-2001-Ski Nautique in '83? |
Andrew McBride
This has really got me wondering now. The t*tle says 83. Here is what has me confused:
1. the front air duct is different from 83's, more like the 80's. The top air duct piece is fiberglass, it isn't the wood one. 2. The rear seat sets on the ground. There is no base that raises it up. 3. The windshield had the vent windows where you could turn them out and get air, but they were broken so I replaced them with a solid piece of glass. 4.http://www.correctcraftfan.com/diaries/details.asp?ID=817&sort=&pagenum=2&yrstart=1981&yrend=1985 The paint scheme looked ideticle to this boat (minus the gold 2001 part) before I stripped the paint off. 5. I see what you guys mean about the bottom rear part, my boat is flat, but the other 83's have the arch on the bottom. This has really got me wondering. I deal with cars a lot and see sometimes that in the factories they will use the last years parts for the next year productions. Like for example early production cars in 65 may have some 64 parts that were left over, so they use those parts up before going with the 65 parts. That still wouldn't make sense, because the shell of my boat looks like an 80 I believe. |
Andrew McBride
stang72
1982...was'nt that when the"2001" was introduced? Andrew's boat would have to be before that right? regardless ,the project is going well though! Wish I could do that stuff when I was a student Way to go Andrew!
SMay81SN
Groupie Joined: June-22-2005 Location: United States Status: Offline Points: 92 |
Andrew,
I'm with markb, I think the boat is older then a 83, more like a 77-78. The front air scoop does not have the teak strip top on it. I would really be suprised if it truely is a 83. Have fun with the project. Scott |
Scott
Our 94 SN |
markb
Andrew,
That boat is not an 1983, it's more like an '81. Note the dead flat bottom when veiwed from the rear as brimeg said. Not that it matters and I'm suprised that no one here picked it sooner.. |
Andrew McBride
Brian,
yeah I am 99.9% sure it is an 83'. I remember wondering that myself until I checked the t*tle, and also the vin shows the year in the digits. I don't know if maybe the rubber bumper guard is throwing you off. We did away with the aluminum stuff and went back with the rubber stuff to bring the boat up to date. The one thing with the year that has thrown me off is the front air duct. I don't know if I have ever seen an 83' with its style, normally it seems like they have the two black louvers on either side. I dunno though! |
Andrew McBride
brimeg
Newbie Joined: September-13-2005 Location: United States Status: Offline Points: 33 |
Andrew:
Looks great. . . I have to repaint a 78 and may do the same with the dash. Quick question for you though. . .are you sure yours is an 83 Ski Nautique. Back end doesn't look right for an 83 or else I have been inhaling to much resin fumes. Keep up the great work! Brian |
Andrew McBride
Convo: No, there is no relation in S. Carolina area.
John: Nice boat, I remember seeing your boat on here awhile back and thinking wow that is one clean boat. This project is both my brother and I's boat. My projects are 3 hours away from college so that keeps me from spending all my time hiding out in the garage. When I am at home I have a tough time getting out of the shop. I work in marketing PT while going to school FT. I work hard and save my pennies. I love to do bodywork, paint, and fabrication which keeps my budget cost down. Markb: You know we were going to paint the dash black but we talked ourselves out of it due to the heat of black. I am not for sure what kind of seats we have. I believe they are standard. They are the full rear seat, the front benchlike lookout seat, and the bucket captains chair. We had the seats custom re-upholstered white w/ 3 black thin stripes. Turned out great. I wanted to do the interior from a newer style Nautique, but couldn't find any at a decent price. I am considering building a moveable chair to go behind the captains chair due to all that dead space.-Like the new nautiques have. I will add a picture of the dash to my web so you can see it a little better. |
Andrew McBride
markb
Excellent work Andrew, I am doing the same with 2 boats, a '76SN and '81SN. My GF was onto me about painting the dash white instead of the standard black. I didn't agree at the time but seeing how yours turned out I'm a convert :-) Does your's have the standard interior? You going to re-skin that or do a full custom ala 1986+ |
jbear
When do you find time to study? And you sure must have some kinda good job to be in school and have cool toys. I musta misspent my youth..........john
convo
Newbie Joined: July-20-2005 Location: Edinboro Pa Status: Offline Points: 38 |
Are you related to a Mike McBride?? Lives in NC.
Andrew McBride
Thanks guys, I am excited to see it come together. I still haven't found an engine yet. The girl I bought the boat from let the boat fall apart. Block and 1 head was cracked. I am probably going with a rebuilt 351W engine. It should be ready to go this spring. Final Assembly will be over X-mas. I am in college so my time is limited to work on my projects!
lol, no the camaro won't be my tow rig. That car has 1,300 hours in it. 68 Camaro, Fuel Injected Small block, TH400 trans, Corvette brakes, custom suspension, 17" custom wheels, rhino-liner on the underbody. Custom Interior and still can't decide on paint. I am leaning towards a blue simiar to the boat! All the work has been done by me on both boat and car. |
Andrew McBride
stang72
Andrew...it's lookin great!
It won't be too long now before she's in the water...unless like me, you have to wait for spring! Keep us updated! |
bkhallpass
Looks like it's gonna be great. Can't wait
for the final pics. You gonna pull it with that classic camaro. BKH |
Livin' the Dream
Andrew McBride
Here are a couple pictures of a 83' Ski nautique I am restoring. The floor has been replaced and re-fiberglassed. All New Seats that are white with black stripes. The boat is finished now, these pics are a few months old. I plan to add a custom black tower, bimini top, tint the windshield and I have a set of 99 Ski Nautique decals that will go on soon.
The trailer has been restored and painted semi-gloss black. I took the front fenders and had them rhino-lined. Here are a few pics. http://photobucket.com/albums/a312/almcbri/?action=view¤t=BoatBlue.jpg |
Andrew McBride
