Anybody in the south NOT winterize? |
Post Reply | Page <12 |
bkhallpass
Sure we winterize. Thermos full of brandy and
hot apple cider, a blanket, and a couple of wetsuits. Seems to work well BKH |
Livin' the Dream
jimbo
Senior Member Joined: September-07-2004 Location: United States Status: Offline Points: 473 |
I'm in New Braunfels. I didn't winterize last year. There were some nights when I got nervous and would put a light in the doghouse. I've got the boat on the boat lift and don't plan to do anything to it this winter (as far as winterizing) unless it stays below freezing for over 24 hrs. Then I might have to take it for a spin to get it warmed up again. My wife won't let me bring it in the house.
tleed
Senior Member Joined: August-24-2004 Location: United States Status: Offline Points: 267 |
I live in Virginia and I skipped winterizing this year. Nothing to winterize since I pulled the motor. Anybody else use this method?
What do you mean "winterize" south of Houston? When you can measure winter in minutes it doesn't count. I lived in Friendswood & League City, TX for a while. Thomas |
hollywoodswole
Newbie Joined: December-06-2005 Location: United States Status: Offline Points: 33 |
Thanks fellas. That's kind of what I was thinking, but this is my first winter with my boat.
88skisupreme
Groupie Joined: September-13-2004 Location: United States Status: Offline Points: 50 |
I live in Austin and I just drain the block. If it gets really cold, like its doing right now, I dump a little rv antifreeze in the exhaust manifolds.
Just be sure to run it at least once a month to keep the engine lubed, if you're not going to fog it. |
64 Skier
Senior Member Joined: February-08-2004 Location: United States Status: Offline Points: 415 |
If temp's have been in the 60's on average and you have the hood closed, that engine is the "heater" when the temps drop in the 20's and it would have to stay in the 20's for a few days in order for the engine to drop to 20 degree's. On rare occasions if the power goes off the old light bulb trick under the hood may not work, but I've never experienced both power loss and temp's below 20 for more than a few hours below I20.
Same principle in the summer. Shut that monster 289 down after an evening skiing and you still feel the heat 12 hours later the next morning. The engine and hood are a great combination. I still suggest you pull the rubber impeller just to keep it fresh, drains the majority of water and is easy to re-install. It's also very easy to drain the block so a little bit of PM even when you ski on occasion shouldn't deter you from climbing in when it's cold outside. |
882001
Senior Member Joined: October-21-2003 Location: United States Status: Offline Points: 332 |
two words drysuit! wetsuits yuk. i dont winterize in houston
kemah texas
1988 skinautique "2001" |
jbear
Lake Wales Fl; They don't even sell antifreeze here! All those years in Ohio, I never knew what I was missing. Enjoy it year round, life is short!...john
Bob's2001
Senior Member Joined: March-28-2005 Location: Lake Jackson TX Status: Offline Points: 241 |
I am south of Houston, Lake Jackson, and I don't winterize. I don't see the point in it when the "cold" weather is 40 for 2 days. I am considering a wet suit also.
Bob Ed
83 2001 |
hollywoodswole
Me and my roommate are thinking about just getting wetsuits and still getting to the lake 2 or 3 times a week. It rarely even gets below freezing here (I know last Christmas I was wearing shorts.)
What's the consensus on not winterizing and just running it through spring? BTW, I am near Houston. |
