  New Posts New Posts RSS Feed - 1986 SN 2001 Engine/Carb Determination
cjackson6263 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjackson6263 Quote  Post ReplyReply Direct Link To This Post Topic: 1986 SN 2001 Engine/Carb Determination
    Posted: September-17-2012 at 8:47pm
Recently purchased a 2001 SN 1986 model, and the engine/trans detail information decal on the valve cover is worn away. I have the model/serial number tag information but after reviewing the PCM owners manual there is not a decoder which helps me determine if this is the 351, 302/2 or 302/4 model. Need to determine correct engine/carb configuration so that I can order parts for a carb rebuild kit. Can anybody help? Point me to a serial number decoder?
Thanks,
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjackson6263 Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2012 at 8:52pm
FYI I located the Motocraft Carb ID number plate. It states EOJL-9510-CA which equates to a Holley 4BBL specifically for a 351W motor. Can anyone help confirm this?
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2012 at 9:11pm
to determine the carb number, you'll need to look at the carb itself.   Take a look at the top right of the carb. you can't read the numbers in the picture below, but you can see them... they should be in the same location on your carb.   there are more numbers on the drivers side of the carb also that could give you a clue as to which rebuild kit to order. Ski dim or My correctcraft parts could both help you to get the holley OEM rebuild kit. 2 barrel or 4 barrel is easy to deterimin, look down the throat of the carb and count the "barrels"   the one shown below is a 4 bbl, you can see two of the bbls in the photo, the other two are lower and are on the back side
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjackson6263 Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2012 at 9:22pm
It is a 4BBL Holley, the numbers in that location are as follows:
LIST-1850-3
0657
According to the Holley site this makes it a 600 CFM unit.
Thanks for the tip!!
Anyone with thoughts on confirming the engine size/model?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2012 at 9:23pm
Welcome Chris. Don't go by the number on the tag-go by the
List # on the airhorn like in the picture below.Also when
you ask about a kit make sure it has the secondary diaphram
too some kits do not have it. The power valve in the new
kits need to be changed,you want a 6.5 not the newer 2.5.
Holley kits are one of the best,some others have gone here
to get their kits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2012 at 11:19pm
good picture Gary    I didn't have a better one at work, yours is much clearer!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjackson6263 Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2012 at 12:08am
Thanks guys. Ordered the rebuild kit, secondary diaphragm and 6.5 power valve using the LIST number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2012 at 12:57am
Thanks Kris since it looks like I know what I'm doing with this camera,I must need a new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2012 at 2:46am
yeah I think my work is on the same schedule with Autocad :)   ever time you get really fast with a version, they upgrade to the next
OP,   Glad you got it figured out! my holley rebuild was pretty smooth, not a lot there. If you haven't done a marine holley before, you will need the special bit for the metering block... I don't remember what it was called, but if you do a search on here, my rebuild thread has the special tool name in it. also, the J tubes in your carb have to come out to remove the butterflies, they come straight up by tapping a very small flatblade into between the carb body and the bulb in the tube.   work it out by tapping and prying, but do not twist, you will break the j tube...
TimSpangler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimSpangler Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2012 at 3:23pm
I've been using Acad professionally since R9, I am currently on ACA2011 and if I had a screenshot of my screen from R9 it would probably look much like it does today. I use keyboard shortcuts and no toolbars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjackson6263 Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2012 at 6:57pm
Finally got around to rebuilding that carb...turned out the electric choke was burned up...of course that doesn't come in the kit...ugh. New problem, I noticed some foam in the oil...looks like I'll be replacing some head gaskets! Great news...
I still have not identified the correct engine size and year so I can't order the parts. A little help??
Here's what the PCM Engine data plate says:
Model: PRD WR R10
Serial: 252 978
Firing Order: 18456273
5Y45101F45F4E
Can anybody help me identify the engine size and year?
Thanks,
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2012 at 9:22pm
Chris,
A good starting point would be the engine manual in our own reference section.
