  New Posts New Posts RSS Feed - battery box
battery box
danman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danman Quote  Post ReplyReply Direct Link To This Post Topic: battery box
    Posted: April-06-2004 at 11:39pm
my 78 has a small rubber hose right at the bottem of the battery box that runs between the engine bilge and the box
I don't know if everyone else has this problem, but mine gets water in it every time out. Is there something I can do keep the water out?
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2004 at 11:23am
I have the same problem on my 79. from what I can tell the bilge is in the wrong spot on mine. The low spot seems to be in front of this hose and to the drivers side. I plan on relocating my bilge to this area and away from the drain in the haul.
tryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2004 at 6:22pm
yo dan, your pm didn't link. i moved the battery box up into the bow on the port side for better weight distribution.
look for a scupper (one way valve) for that size hose or you can turn the old battey box in to a 6-pack cooler and plug it.
