Does the code remain when battery i out? |
JophWeud
Newbie Joined: August-18-2012 Location: Sweden Status: Offline Points: 31 |
Posted: October-27-2012 at 5:35pm |
Hi, does the code, My personal, remain, if I take the battery out for the Winter?
Or do I have to know the master code? ( the boat is pre-used and former owner gave me a minimum of documentation....) Grateful for some answers / Joe |
--I will never be a grown up....almost 40--
Tim D
There are three types of codes for the keypad. The master embedded code, which is not changeable, primary user code and the secondary user code. My manual doesn't mention anything about loosing the code if the battery is disconnected. It does mention not to let the cables touch or ground out, that will kill the keypad. The two changeable codes are easy to do, and if you change the primary code, the secondary is erased.
Tim D
JophWeud
Thanks, Then I hope My code, guess primary, still is there in the spring...
( what fors you mean with touch or ground out..., you know Im Swedish.., please explain in other words) / Joe |
JophWeud
..does... ( Swedish dictionary on iPhone ..:( )
Tim D
Don't let the positive and negative cables touch.
Tim D
JophWeud
Even if the battery is removed?
dochockey
Gold Member Joined: September-16-2009 Location: Colorado Status: Offline Points: 638 |
Thanks(1)
Joe welcome to the family great boat
So your in the Stockholm area ? that is pretty far north, whats the water temperature there ? Kirk |
1989 Teal Ski Nautique
1967 Mustang Harris Float Sunfish |
mark c
Gold Member Joined: May-09-2012 Location: Massachusetts Status: Offline Points: 534 |
Yes even with the battery removed, your primary and secondary codes are stored in EEPROMs inside the dash unit and probably kept active with capacitors, if you touch the basttery cables together with the batterys disconnected, you will discharge the capacitors and the codes will be lost. Then you will need to know the master code to reinstall your codes. The master is hard programmed into the dash unit and can not be changed.
JophWeud
Oops.... Have to check...
Tnx |
JophWeud
Hi, tnx!
In Sweden, Stockholm area, it is about +2 C, first snow arrived thursday. All the boats are up, or is ongoing at the time, the winter is here.... and the water is cold! Rather short season for boating and watersports, but lovely winters with lots of snow... |
Bri892001
Thanks(1)
Can you get master codes from a a dealer using Hull ID? I know on the automotive side you can get that kind of info from a dealer using Vehicle Identification Number.
atikaquiresi
Newbie Joined: November-15-2012 Location: United Kingdom Status: Offline Points: 7 |
Thanks(1)
hej .. Jag kan hjälpa dig med språket ...
JophWeud
Hahahaha!
Thanks a lot, I guess that you have seen that I have to get som help with the language....:-) Tack så mycket, tror mig förstå att du sett att jag behöver lite hjälp med språket....:-) Are you a Swede? Är du svensk? // Joe |
