'08 230 gel coat cracks, leave 'em or fix 'em? |
super01
Groupie Joined: June-22-2009 Status: Offline Points: 41 |
Posted: October-28-2012 at 5:27pm |
There are some cracks in the gel coat around the rudder mount in my '08 230, they are pretty long and radiate out both sides and aft. They appear to be cosmetic, I can have them fixed, or should I leave them? If they are fixed will they come back again?
Anyone else have this issue with their '08 230? |
Waterdog
To fix stress cracks the right way, grind them out all the way to the fiber glass, then see what you have. If its only in the gel coat - Fill with thickened epoxy and top with gel coat. And sand, sand, sand. Repaired right they won't come back. Can you inspect the area from inside the boat? |
Careful!! The gel will not stick to the epoxy. You will need to cover the epoxy fill with vinyl ester first then go with the polyester gel. Still, the epoxy repair is the way to go. |
Waterdog
Pete,
If groves from a die grinder are filled I think it would be OK. (1/4 inch wide or less) BUT - If the whole area was sanded then I'd use a vinyl ester bond coat. Your probably right, sand the whole area to do it right. |
Andy, I just wanted to "play it safe"!!! Yes, a small routed out crack should not be a issue but, the vinyl ester conversion coat is the best safe way to go. |
SN206
Grand Poobah Joined: February-25-2009 Location: Fort Worth, TX Status: Offline Points: 2339 |
It's under warranty so why not?
super01
I will try to have a look from inside the hull. I'm not a bodywork guy, I stick to the mechanical and electrical. So I plan to take it to my local Nautique dealer for the repair. I will talk to him about how the repair will be done, what materials they will use, etc. per your recommendations. It is covered so cost isn't a concern, I just don't want to make it any worse than it is.
SNobsessed
Did you hit something? It seems odd that this area would crack unless it was subjected to unusually high stress.
Get it fixed right - that boat has a lot of life left in it! |
AAM196
Gold Member Joined: October-23-2012 Location: Pittsburgh, PA Status: Offline Points: 846 |
I'm with Chris on this. First, how did this happen? Second, find a good fiberglass/gel coat guy to inspect and quote if you aren't up or have knowledge to fix yourself.
Doesn't sound like mfg defect , but if so, they might cover repair. Any pics? |
super01
They were in the hull when I bought the boat. The previous owner claims that the rudder never got run into anything. There don't appear to be any cracks around the prop strut or any other running gear. I plan to have the hull checked thoroughly by the Nautique dealer before they repair it. The cracks do look like they originate at the forward two screws of the rudder mount. It would be unusual for CC to miss chamfering these holes, but not impossible.
