351 Rebuild |
rubitlarman
Newbie Joined: May-07-2005 Location: New Zealand Status: Offline Points: 32 |
Posted: January-03-2006 at 1:08am |
Can somebody please tell me which type of rebuild kit I should be using to rebuild the 351 in our 93 sport? It has run the bearings and requires a crank grind but the pistons are sweet so only needs a re-ring kit. I've been looking at some kits from Summit Racing but don't know which one would suit this engine as some of them say they are for truck application. Does anybody know what the difference is? At the moment i'm looking at P/N FEM-2056116M-011. Any help would be much appreciated.
Rob |
More power is needed till the fear of speed is overcome by the thrill of acceleration
AWhite70
Senior Member Joined: March-05-2004 Location: United States Status: Offline Points: 242 |
Looks to me like most of that kit would be usable. Although you may need to purchase some additional marine specific gaskets. Your engine should be LH rotation so that will match an automotive engine so the front and rear seals should be usable. I rebuilt my engine with a marine gasket kit from Federal Mogul and still had to buy waterpump gaskets separate, none of the ones in the kit worked. Also I’ve been told that head gaskets, intake and exhaust gaskets are all marine specific but no one has told me what’s different. I couldn’t tell a difference visually.
More importantly why are your bearings toast? Are your cylinders ok? What about your cam bushings? You may want to also look at replacing the oil pump if the engine failed for a lubrication issue. |
rubitlarman
Cheers for that, I can't work out why a supposed marine engine gaskets would work any different to a car either - probably just a $ game.I think somebody before our ownership may have done a bodge job to get her going and flick it off. The bores will be fine with a hone and the don't have any reason to suspect the oil pump as has always had good oil pressure. The cam is poked, particularly as we had one lifter not working.
Jim_In_Houston
Nice post rubitlarman but what language are you speaking? A word of warning about engine parts for marine applications (even though I don't think I fully understand your post): it's what you don't even suspect that will kill you. (You can quote me on that). For example: Are you aware that the tolerances between the pistons and the cylinder walls are different between marine and auto engines? And for good reason.
wrollema
Newbie Joined: February-12-2005 Location: Canada Status: Offline Points: 21 |
I agree with Jim_In_Houston be very careful with using non marine parts. Pull the part numbers off the defective part and go to your local Ford dealer and he can advise whether the part cross references over to a non marine part. The clearances on a marine engine is quite different than a truck or auto engine, if you are getting the crank turned make sure the machine shop understands that it is for a marine application. Also, the bearing for the crank are full grooved bearings; bearings for auto and truck are not.
64 Skier
JIH...can you expand on the differences in clearance in a marine engine versus auto.
I rebuilt my 289 and although Ford and H&M told us what to do when we bored her I was so busy trying to finish the engine I can't say I learned too much. Good advice from people who are in the know is a must so I fully agree with your post. Once complete, she started up easily and yanks some pretty big boy's outta the water...or over the top of their ski. Just trying to learn! |
jos1
Newbie Joined: January-07-2006 Location: Netherlands Status: Offline Points: 21 |
I read tolerance and clearance. both ment the bearing gap and piston gap? The sizes can be found on the PCM manual found on, also the gap, manual on PlanetNautique's website.
The 351W is a more robust type therefore its is used in boats and trucks. Bearing caps are more robust, source FordRacing. A marine runs for sure on higher nominal RPM as a car, there for some critical parts are optimized for endurance. Some parts are not that stressed due to the more even load distribution in a boat. Cars are mostly used every day, petrolboats not. |
jos
Jim_In_Houston
64 Skier, I am not the one to ask about clearances. I just know, from reading this forum, that there are important differences that I would have never suspected. There are many on this forum that know a lot more than I do on the subject. I am sure someone will chime in and explain the differences or point you to the right thread. I am happy to hear you have a good running 289. I am very happy with my little 289 - it will through you back in the seat when you hit it and run strong all the way to 5500 RPMs.
rubitlarman
Yes but are these fact's true or just something that somebody heard from a friend of a friend who's mate told him so? I havn't found anything in croncrete that says that there is any difference. Apart from things like camshaft profile.
AWhite70
Marine engines have the same bearing clearances as automotove engines.
Piston to bore clearances however are not the same. Marine engines run slightly larger piston to bore clearances. This is done because marine engines tend to run higher sustained loads than automotive engines. This results in higher piston temperatures, which results in more thermal expansion in the piston. Marine engines also tend to run colder coolant (lake water) than an automotive enigne which results in a colder block and cylinders which means the cylinders expand less than an automotive engine. So in short the cylinders don't expand as much and the pistons expand more....this results in the need for more clearance. I learned this first hand neither me or my machine shop knew the difference in marine specs (not a lot of marine engines built in the middle of Iowa). The automotive clearance spec on my pistons was .0015" min. and my machine shop set the clearance to .002-.0025" from personal experience. The engine lasted ~25hrs before scuffing 2 cylinders. Fortunately the damage wasn't terrible and the machine shop was able to rehone the block to set the proper clearance and get rid of the scuffing. Clearance was set to .0035-.0045" and the engine has been running great for 50hrs since. Fortunately the machine shop felt bad and since neither of us knew the difference between marine & auto. specs we chalked it up to a learning experience and split the cost 50/50, so the second rebuilt only ended up costing me about $100. |
jameski
Senior Member Joined: May-18-2004 Location: United States Status: Offline Points: 368 |
rubitlarman, this is a link to one of the threads Jim_In_Houston is refering to:
Piston/Cylinder Clearance Thread I'm not vouching for the accuracy, just passing on the link. But, I do agree with the reasoning - higher temps in the combustion chamber (from higher RPM, and always being under load) and lower cylinder wall temps (from raw water). |
64 Skier
AWhite70,
Thanks...great explanation. I remember your post a while back asking this question about piston to cylinder wall clearance, but never followed up on what happened. I rebuilt my 289 and remembered this discussion with the machinist (bracket racer) and Holman and Moody, but quite frankly I was already scratching my head just getting up to speed with reverse rotation and the solid lifter cam and plain forgot the answer. Have about 40 hours on .004" and running great. I don't know the old '64 1/2 solid lifter cam spec's but it is fun to play with the lash. Thanks! |
64 Skier
AWhite70....looked at you boat pic's and don't get me wrong...she's a beauty...but what really caught my eye were all the kids sandals in the boat. My kids are much older now and did not get the chance to grow up with a CC. What a great opportunity your providing your kids! Keep it up.
Now I'm going to figure out how to post my boat pic's. I've been on this site way too long to have not posted my pic's. |
AWhite70
64 Skier-You must not have been looking at my boat. First, I don't have any kids and second none of the pictures of either of my boats have sandals in them.
When I do have kids though rest assured they'll get plenty of boat time as long as they're interested. |
64 Skier
Sorry, I was looking at Jameski's boat! No kids....go get some!
If you want some kids....I can send you a few....more expensive than a boat....always's talk back....usually bring the boat back with something wrong or running on empty....and getting ready to go to College. Situation Normal. |
jameski
Yep. That's my mess. The kids have almost as much fun as I do. My best memories from this past summer were the days we were camping at a Corps of Engineers park and all the kids from the surrounding campsites took turns learning to ski. Their families either didn't have a boat, or they had a fishing boat, but no skis. None of them had ever been pulled before. Our ski boat was quite an attraction for them. We were pulling three and four at a time (tubes, knee boards, skis...). Even a couple of the parents came over for a pull.
My family didn't have a ski boat when I was young, so I can really appreciate the privilege. I love to share the fun - especially with people who don't have a boat. I didn't get a single pull on some of those days, but as I said, they were the best memories of the year! |
jbear
jameski: I too like the pics of your beautiful boat with the kids stuff in it. Makes me jealous. Our little boy is now 35 but when he was growing up I never had to worry about where he was or what he was doin'. I knew he was skiing with us or someone else in our ski club. Never had to worry about him all thru the teen years until he went in the Navy. My Dad taught us to ski but we could never afford a boat. So it has been great owning C/C's all these years to share with family and friends. Sorry this ran so long...jbear
"Loud pipes save lives"
shilohnautique
Newbie Joined: September-29-2004 Location: Lake Hartwell Status: Offline Points: 18 |
I rebuilt my 89 sn 351w from a car kit, even used the mild cam that came with it bored .40 over for the last 600-650 hrs havent had a problem yet. Kit only cost me 300 bucks came with new pistons, bearings rings cam.
phospher
Gold Member Joined: July-19-2007 Location: United States Status: Offline Points: 557 |
LOL, have my first on the way due in August. "Situation Normal" that's funny... |
