  New Posts New Posts RSS Feed - 351W camshaft specs?
E4ODnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Topic: 351W camshaft specs?
    Posted: December-15-2012 at 3:48pm
Does anyone have detailed Original Equipment Manufacture camshaft specs for the various 351W marine engines offered over the years? By detailed I mean lift, duration, lobe centres and whether there was any built in advance or retard?
Robert
1993 Bayliner 3288 "Hocus Pocus"
351 Fords, converted to tuned port programmable EFI
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2012 at 1:00pm
If the specs simply aren't available, I have another idea.
If anyone has a dead original cam they could donate to the cause and send me (I'll pay the shipping) I'll degree it and post the results.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2012 at 1:14pm
Ive always heard and read that stock 351w marine cams (both standard and HO were in the .450 lift range. This was posted not too long ago and is consistent with that:
Originally posted by j.mccreight@hotmail.com j.mccreight@hotmail.com wrote:
STD 351w camshaft specs
Duration 206 int./221 exh. @ .050
Valve Lift 0.445 int./0.453 exh
115°
HO 351w
Duration 210 int./221 exh. @ .050
Valve Lift 0.453 int./0.453 exh
115.5°
Not super detailed info with all the valve event timing, but a start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 10:37pm
Thanks TR, that's probably about as good as it gets.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2012 at 12:56pm
I just checked my shop manual and the 351W EFI truck engine shows an intake lift of 0.278" and an exhaust lift of 0.283". Rocker ratio is listed as 1.61:1 which places the valve lift the same as the 240 HP marine. Unfortunately this is all the information the manual has on the cam other than wear limits and that sort of stuff.
Robert
