  New Posts New Posts RSS Feed - Teak Swim Platform Restoration Questions
RedandWhite73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedandWhite73 Quote  Post ReplyReply Direct Link To This Post Topic: Teak Swim Platform Restoration Questions
    Posted: February-09-2013 at 8:08pm
I recently acquired a teak swim platform for my '73 Southwind. I spent some time searching through old threads to find instructions on restoring it, but couldn't find what I was looking for.
Does anyone have any recommendations? The gentleman at the hardware store suggested that I lightly sand the wood, then apply teak oil. I thought it would be best to run this past the board.
Thanks,
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 8:49pm
Dan,
All you need to do is go to the CCfan FAQ thread and it will link you to almost anything you need to know. If not, get back to us.
BTW, the guy in the hardware store doesn't know how to clean Teak. Get one of the Teak refinishing kits. Cleaning is the most important step. I also recommend gentle use of a pressure washer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 9:58pm
Brass brush for use with the cleaner. Sanding is optional between coats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedandWhite73 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 11:54pm
Thanks for the links. Looks like this topic has popped up a time or two.
snipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snipe Quote  Post ReplyReply Direct Link To This Post Posted: February-12-2013 at 4:14pm
I used the three step Starbrite method with excellent results. I did power wash first (lightly) then the cleaner, then power wash lightly, let it dry and follow the directions from there. I did NO sanding. It gets too smooth for kids getting out of the water.
OldSchoolBlue84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolBlue84 Quote  Post ReplyReply Direct Link To This Post Posted: February-12-2013 at 10:36pm
Good job snipe! Will be doing mine this spring. Did you use a certain brush?
Post Options Post Options   Thanks (0) Thanks(0)   Quote snipe Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2013 at 9:13am
I used a bristle hand brush for the cleaning just to rub the cleaner in good; then lightly power washed. The oil was applied with a small paint brush. Nothing special. Don't overdo the power wash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2013 at 10:34am
TSP from Home Depot / Lowes works well for cleaning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolBlue84 Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2013 at 10:49am
Thanks guys, this will be added to my to do list before the boat hits the water this year. List keeps getting longer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2013 at 10:32pm
Greg,
The TSP may work good for cleaning but not brightening. I as well as Egon recommended the teak kit since it has oxalic acid that will remove the gray color.
