  New Posts New Posts RSS Feed - How do I get these off?
Frankenotter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Topic: How do I get these off?
    Posted: March-24-2013 at 1:28pm
Well, its manifold time and I have a HUGE concern. My port side manifold is sooooo corroded that there is nothing left of the bolt heads.
I'm planning on grinding the heads off, pulling the manifold off, and then seeing if there is enough left of the bolt to get a vice grip on to slowly back it out.
If the shaft of the bolt breaks I think I'm screwed. I've been hitting them with penetrating oil for about a week now and someone suggested heating the area around the bolt with a torch, but that doesn't seem like it would be good for the head.
I'm all ears to suggestions on all or part of this job.
Chris
1999 Ski Nautique 196
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2013 at 1:34pm
What do I do if the worst case scenario happens and the bolt dreaks off in the head?
gR@HaM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2013 at 1:57pm
How's about chopping the head off with a small cutting blade on a dremmel then using vice grips to get it out?
Failing that, welding a hex bit to the bolt?
Or using a small Irwin easy-out?
'82 Ski Tique
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2013 at 2:08pm
A cut off wheel will work.
Cut the head off or cut an "X" in the
head down to the shank. and use a chisel.
Soak them in penatrating oil the best is
1/2 Trans fluid and 1/2 acetone, easy to make yourself.
And keep soaking them.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2013 at 2:08pm
Resist all urges to use an easy out. If you have a mig welder weld a nut on to what you have first and see if you can get them out.The heat from welding will help break the rust.If that don't work grind the head off remove the manifold and then weld a nut on. Replace with stainless and use anti seize. Some may come out with a vice grip but be careful not to mess them up so much that you cannot weld a nut on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2013 at 2:16pm
I agree, but I wouldn't be afraid of cutting them off with the cut off in a Dremel. You will them get a better shot at getting the penetrating where it should go. The problem with a "easy out", is the soc. hd. cap screws are grade 9 and very hard. They are tough to drill even with carbide bits and an easy out won't grab.
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2013 at 2:21pm
I just cut off 4 of those, cut off wheel on a die grinder and some paitence is all it takes. If you don't want the manifolds it a little easier, it's hard not to saw into them a little. I also broke the spark plugs off on purpose to keep the motor sealed while I worked, pipe plugs would work for that too.   I didn't remove the bolts from the heads, but I got a ground off head bolt out of the block and anothe out of the exhaust manifold. I used acetone and ATF on both and let them sit for at least a day. They hardly put up a fight when I got around to taking them out. If you have a welder you can tack a nut on them to make it even easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2013 at 2:32pm
Hit the bolts fairly hard with a ball peen hammer.
The scale rust will jump off and help loosen the bolts.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2013 at 3:29pm
Good info gents. I'm going by the boat one more time today on my way to work and ill hit it with the ATF mix.
I've been warned my several people already not to attempt an easy out due to bolt hardness. Ill see if I can get my welding dude to tack a nut on.
Next weekend will be d-day for this project.
Chris
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2013 at 6:46pm
take the heads of the bolts off pry the manifolds off, weld nuts on where you can hit the studs with a hammer, i have to say i have been using a new product i always used pb blaster but now i heat the studs , and when cool i have been using crc freeze off , whatever it is it acts like freon and penetrating oil all at once
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 12:24am
Well the bolts have been soaking in oil all week so I came back to them today for a test.
It didn't go well.
All I've done so far is the riser bolts (haven't even touched the manifold bolts which are in 10X worse shape).
Broke 3/4 after using ATF/Acetone mix and sitting for 4 days. These don't matter because the lowers are garbage anyway but it makes me nervous for the big show.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 12:34am
Those manifolds don't look too bad, your probably going to have to tak a nut on them since they're so short. On the heads you should have much more to work with, but since you're going to tak some of them you might as well do all of them. Another round of ATF/Acetone won't make it any harder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 2:34am
The risers are in great shape but the lowers are cracked due to winterization from the PO.
I will be trying the welding technique for sure.
I've also been reading a ton of info on ford sites about the miracles of PB Blaster. Anyone want to chime in on the ATF/Acetone vs. PB Blaster oils????
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 2:55am
I'm sure someone will post the test, PB Blaster is about dead even with WD40. ATF/Acetone blows everything away by a good margin. It's quite flammable and I would guess that my safety people would frown on it with no MSDS, but I know quite a few machinists that keep a bottle around for the difficult stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 8:18am
Here's the list of torque requirements copied from the other thread:
Penetrating oil ..... Average load
None ...................... 516 pounds
WD-40 ................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ......... 127 pounds
Kano Kroil .............. 106 pounds
ATF-Acetone mix.......53 pounds
I don't even consider WD40 to be a penetrating oil so that puts PB at the bottom for me. Kroil is a on line order only so when I was taking my 1927 Flexifour apart and trying to break the rusted pistons loose, I did pick up a can of PB. A week went by with no luck and then the Kroil came in. The next day after using some of the Kroil, all four pistons were loose. I ended up using the PB as a honing lubricant!
Evidently the Ford guys on those sites fall for "Madison avenue marketing" BS and they shop at HD!!
If you fail at getting them out, a machine shop with an EDM can burn them out. It may be cheaper than a new set of manifolds and risers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 9:13am
I think we have established that the manifolds are beyond saving for other reasons. He is concerned about the heads. Personally, id do my best on them but would know in the back of my mind that new gt40p heads would bolt on 45hp for $450... So if things go south that's not all bad news.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 11:29am
the way i weld nuts on is . grind the top of the old bolt head put the new nut on and weld the hole , if you have the option on say a 3/8 manifold bolt i try to use a 7/16 or even a 1/2 " nut over it you have more hole to weld. if you have difficulty getting the nut to stick try and die grind a slot into the top of the bolt so the weld will get into that .
Waternut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 12:22pm
Well if it comes down to it, I've got a set of heads that I pulled off my boat during the GT40p head swap. They're in good shape and just sitting on my shelf taking up room so I'd let them go pretty cheap. Shipping isn't cheap though...
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 5:24pm
i have a pristine set of 428 cj heads from my old jet drive, i bet you could find a bb ford short block to fit in there
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 7:00pm
Now that is project scope creep!
Dank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dank Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 7:24pm
So maybe someone has already asked, but if the manifolds are cracked due to the PO no winterizing the boat...how do you know they drained the block? Maybe I can learn something :)
"I don't know what the world may need, but a V8 engine's a good start for me"
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 9:20pm
I went & viewed the boat. I verified (by taking block drain plugs out) that block was drained. The PO was not mechanically inclined & did not know that there were other things to drain too.
The engine also turned-over via breaker bar.
Dank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dank Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 9:28pm
got ya...just caught my attention and I hadn't seen anyone else ask :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 9:32pm
The engine has an abnormal amount of external corrosion.
It must have been put away wet repeatedly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 11:33pm
Well the day has arrived. I hacked into the manifolds today with mixed results.
The good news ----- 15 out of 16 bolts came out!!!!
The bad news ----- 15 out of 16 bolts came out.....
All of the bolts forward of the Aft-most cylinders came off really nice after being soaked in ATF/Acetone for a week.
The two most aft cylinder bolts (both port and starboard sides), however, were too far gone to get an allen head in.
I started by taking a cutting head on the dremmel and little by little removing the head of the bolts until I could make out the gap between them and the manifold.
The manifold popped right off exposing my two stems.
I took a chance and put a shot of oil and a vice grip on the first one and it literally spun right out.
The same was not true of the other. As I put a vice grip on it, the threads fell apart and I was too afraid to try again. You can see it in the picture above just above my finger.
I guess my last attempt at getting this one off is going to be the welding method. I hit it with ATF/Acetone about 10 more times before I left today in hopes that it will be ready next weekend when I come back to it.
On the starboard side I was not as gentle because the bolts were in much better shape. Here I used a pneumatic cutting wheel and went to town.
When I got the manifold off, I put a vice grip on the stem and they came right out nice and easy.
So.....literally one bolt lays between me and boating season (in theory). Until it comes out my nerves will be shot for the next week or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 11:37pm
Oh.....and before anyone yells at me.......
Those are sacrificial spark plugs in the hole to block little bits from entering the cylinder.
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2013 at 12:58am
You"re doing good you've only got one left and you haven't resorted to the real serious stuff yet. Weld a nut on and I bet the last one will pop out easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2013 at 1:02am
If you can't get a welder, a micro-torch that would heat that shank easy. I would use some flashing to shield the other surfaces from the flame.
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2013 at 2:25am
Chris and Chris, was this boat on Delhi? I remember one similar on a lift up there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2013 at 5:21am
Is it just me or is almost everyone on this site named Chris?
Yes Chris, this was a lake Delhi boat. Bought it from an older couple that were moving and kids were all gone from the area. I know they did have it on a lift as well until the dam broke.
Like Chris said, really nice folks, they just did nothing for upkeep on the boat. It's been and interesting road getting this little hot rod back in shape.
Chris.
