Flickering guages |
2001SAN
Senior Member Joined: June-26-2012 Location: Ireland Status: Offline Points: 244 |
Posted: June-20-2013 at 7:26am |
I plan to clean the grounds on my GT40 to see if it cures the following issues. Not major problems but a little annoying.
1 - Oil pressure guage flickers a little around otherwise appriopriate readings, esp on idle. The guage has always done this. 2 - Tach flickers around appropriate readings, also only round idle. This has only started a few weeks ago. Could this be dodgy grounds or something else? All other guages are solid. All guages are less then 6 months old (Faria replacements). Engine was rebuilt last year. Thanks, Darren. |
A little knowledge is a dangerous thing...
2001 Super Air Nautique 1989 Fairline Corniche 31 www.bannrivercruises.co.uk |
daniel1978
Groupie Joined: June-01-2013 Location: Lower Austria Status: Offline Points: 42 |
Hello!
Of course I never tried it: why dont you just use low voltage without ignition (from a battery or so) and connect it to the Instrument - if it flickers you know where your Problem is! greetings daniel |
1995 Ski Nautique with great slanted ass.
NEW: now with running engine - hurray hurray |
