  New Posts New Posts RSS Feed - Fuse Holders... maybe convert to Circuit Breakers?
boardersdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Topic: Fuse Holders... maybe convert to Circuit Breakers?
    Posted: July-17-2013 at 5:51pm
1984 Ski Nautique 2001
Engine Model PRD WR R10
Pleasurecraft Marine
Right-Hand Rotation from Rear
351 CID -- 255 h.p.
Warner Velvet Drive Model 10-17-003
Direct Drive (1:1)
Mallory YLM554DV Distributor Conversion
One of the (several) problems we had on vacation was with the fuse holders on the panel being loose. The holders aren't tight in the dash and rotated a little when checking the fuses, which actually twisted off the corroded connections behind the dash. My son spent a half hour on his back putting new spade connectors on the loops between the fuse holders for the bilge pump, blower and ignition. (I think we'll be replacing that wiring.)
Anyway, I haven't crawled under there yet. Are the fuse holders easy to tighten? Where can I buy replacements? And, best of all, have any of you guys converted these to circuit breakers, and if so, where to buy those?
Thanks.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2013 at 7:22pm
Steve,
I always push sticking with the original. The fuse holders are a common Bussman.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2013 at 9:11pm
Peter,
Thanks for that info. I did a google search with site:correctcraftfan.com including "Buss" and found the
Fuse pots 1975 style
thread. We'll try tightening them up and if they cause problems, we'll order new ones.
Related question: Any way to "flip" the panel, or do you have to crawl under (with seats removed) to work on the gauges, etc.?
Thanks.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2013 at 6:12am
Steve,
It's a crawl under the dash project!
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2013 at 2:40am
Pete, we're sticking with the originals. My son crawled under and carefully tightened all the fuse holders. One was stripped, so I'll pick up one new holder. He also cleaned all the ignition switch connections, everything clean and tight. We're getting there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2013 at 7:25pm
Steve,
Glad to hear you are sticking to the original!
