Ignition upgrade preferences |
Nauti87
Senior Member Joined: June-05-2012 Location: Central Florida Status: Offline Points: 114 |
Posted: July-21-2013 at 1:46pm |
Ok,
I have come to the point where I believe I need to replace my very old EI module. (prestolite as far as I can tell) This ignition stuff is getting old, I just wanna ride! I only want to mess with this once, so I need to know what the majority is using or prefers, coil included,(ballast or no ballast) and where's the best place to get it. Also, what should be done with the distributor, new springs etc. The boat is an '87 PCM. I only see 25° advance @ 2500, initial set at 10°, the weights move free. I don't want to rev it any higher than that on the trailer. The reason I started this post, is there are a bunch of reading on here that goes back and forth on brands, and what works and what doesn't. Thanks in advance. |
Bri892001
A lot of the gurus on this ste are running the Davis Unified Ignition http://www.performancedistributors.com/
No personal experience but I've heard good things. It's a little pricey but then you're just done. No extra coil, no resister, no questions on wiring. |
Jody,
What's wrong with a point set? Unless you convert to a complete DUI distributor, I do not consider a conversion module to be a "upgrade". Who is telling you it's an upgrade??? |
TX Foilhead
The DUI is by far the simplest, I'm going that way once I get my current issues sorted out, with my luck the bad wire I'm looking for would be the one I need on the DUI. It's not that much more that a complete Mallory with an epoxy coil and ballast resistor, I think it's about $100 on a RR, and there's something to be said for not having to figure out what someone may have done to the wiring in the past.
Nauti87
Pete,
Sorry I miss chose my words,,,, a lateral change. Not really looking to change the whole distributor out just yet. |
Seals
Newbie Joined: May-17-2010 Location: Indiana Status: Offline Points: 17 |
I just bought a complete new mallory distributor for my 79 Nautique From discount inboards. Hoping this Salz all of the past petronix EI module issues that I have been having.
Nauti87
As a follow up, I got a Mallory module, and used the ballast resistor. It runs great so far, hopefully will test it tomorrow.
I went with the Mallory because I've always had good luck with them on multiple cars. I had one Pertronix unit and it failed, with that being said, I'm sure they're probably better than back then. |
1987 SN 2001 Barn Find aka "Nauti" (sold sadly)
1988 MC Anniversary Prostar 190 |
boardersdad
Senior Member Joined: June-18-2013 Location: Wisconsin Status: Offline Points: 409 |
We just got our '84 SN2001 this year. It has a Mallory conversion; not sure if I like it yet.
My old pontoon has a Mercruiser with a Pertronix. I wasn't sure I was a Pertronix fan, but it's been on there for 13 or 14 years and the engine still runs great. |
Nauti87
If it runs, why don't you like it???
boardersdad
Nauti87> "If it runs, why don't you like it???"
Not sure which one you're referring to. Pertronix (on Mercruiser): I had heard of some failures. But mine is doing great, so I like it. Mallory (on PCM): We just got the boat this year and have been working through some issues, which I've been discussing in other threads (for example, momentary cut-out at speed). We're working through these. Once we get them all cleaned up and know that the Mallory conversion isn't an issue... I'm sure I will like it. :) |
