  New Posts New Posts RSS Feed - Who refaces gauges? Ebay tach?
shagit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagit Quote  Post ReplyReply Direct Link To This Post Topic: Who refaces gauges? Ebay tach?
    Posted: July-28-2013 at 11:10pm
I'd swear I saw awhile ago that someone could reface the white gauges from the early 90's.... Tried search with no luck.... Anyone?
Also, there a couple 6k Tach's (a white and a black) that match the same year CC's, and they have an electronic voltmeter/clock and hour meter incorporated in to a small display... Wonder if they can be hooked up to our boats.... Hmmmm.
http://www.ebay.com/itm/VDO-Viewline-Onyx-6-000-RPM-3-3-8-Tach-w-2-Hourmeters-Clock-Voltmeter-12-24-/190871937283?pt=Boat_Parts_Accessories_Gear&hash=item2c70daa103&vxp=mtr#ht_239wt_1141
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagit Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2013 at 11:11pm
This is the reply from the ebay lister:
"The volt and hour meter are run off of your 12vdc house electical panel via 2 power leads."
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2013 at 2:06am
Shagit:
Rod Velde bought all the 90's white faced gauges left. Check with him for gauges except the tachometer, plus he is close to you.
I needed a replacement tach, so I went with the VDO Standard Line Tach - differences: 7K range not 6K, and second marking pointer.... plus the trim pot on the back allows adjustment.
